[SCM] PostGIS branch stable-3.4 updated. 3.4.6-5-g4761b8986
Fri May 29 10:59:20 PDT 2026
the project "PostGIS".
The branch, stable-3.4 has been updated
       via  4761b8986edf899d1e7b61a85f6c8bbbfad8771f (commit)
       via  e8f29dfd8f2b92c6bd7ded7b66e19f36f88005b0 (commit)
      from  be40c14149ec6ab2977f20eeeaf4473f9bfce62c (commit)
revisions in full, below.
commit 4761b8986edf899d1e7b61a85f6c8bbbfad8771f
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Fri May 29 10:59:01 2026 -0700
    News item for #5988
diff --git a/NEWS b/NEWS
index 02ffff50c..a27721103 100644
--- a/NEWS
+++ b/NEWS
@@ -4,6 +4,7 @@ PostGIS 3.4.7
 * Bug Fixes *
   - Flatgeobuf schema mismatch vulnerability (NeuroWinter)
+  - #5899, pg_upgrade issue for non-standard geography SRID (Paul Ramsey)
 PostGIS 3.4.6
commit e8f29dfd8f2b92c6bd7ded7b66e19f36f88005b0
Date:   Fri May 29 16:21:02 2026 +0000
    When doing pg_upgrade on a table with Geography(type, srid)
    column, where the SRID is specified, but not 4326, the SRID
    lookup code will fail during schema transfer as the
    spatial_ref_sys table may be missing and unable to lookup
    the SRID number. This "fix" leans on the fact that most
    SRID numbers in PostGIS are already EPSG numbers so the
    lookup can be skipped most times.
diff --git a/libpgcommon/lwgeom_transform.c b/libpgcommon/lwgeom_transform.c
index 95394bddb..04eb310f2 100644
--- a/libpgcommon/lwgeom_transform.c
+++ b/libpgcommon/lwgeom_transform.c
@@ -176,6 +176,40 @@ GetProjStringsSPI(int32_t srid)
 		elog(ERROR, "Could not connect to database using SPI");
+	 * During pg_upgrade, geography typmod is parsed before spatial_ref_sys
+	 * exists or is populated. Check both conditions via catalog before
+	 * querying the table, to avoid a transaction-aborting error.
+	 * If either check fails, return "EPSG:<srid>" directly so PROJ can
+	 * resolve standard codes from its own database.
+	Oid nsp_oid = POSTGIS_CONSTANTS ? POSTGIS_CONSTANTS->install_nsp_oid : InvalidOid;
+	snprintf(proj_spi_buffer, spibufferlen,
+	         "SELECT 1 FROM pg_class "
+	         "WHERE relname = 'spatial_ref_sys' AND relnamespace = %u",
+	         nsp_oid);
+	spi_result = SPI_execute(proj_spi_buffer, true, 1);
+	bool srs_exists = (spi_result == SPI_OK_SELECT && SPI_processed > 0);
+	bool srs_populated = false;
+	if (srs_exists)
+		         "SELECT 1 FROM %s LIMIT 1",
+		         postgis_spatial_ref_sys());
+		srs_populated = (spi_result == SPI_OK_SELECT && SPI_processed > 0);
+	if (!srs_exists || !srs_populated)
+		char tmp[maxprojlen];
+		snprintf(tmp, maxprojlen, "EPSG:%d", srid);
+		strs.authtext = SPI_pstrdup(tmp);
+		SPI_finish();
+		return strs;
 	static char *proj_str_tmpl =
 	    "SELECT proj4text, auth_name, auth_srid, srtext "
 	    "FROM %s "
Summary of changes:
 NEWS                           |  1 +
 libpgcommon/lwgeom_transform.c | 34 ++++++++++++++++++++++++++++++++++
 2 files changed, 35 insertions(+)
hooks/post-receive
