[SCM] PostGIS branch stable-3.5 updated. 3.5.6-5-gf72686cca
Fri May 29 10:59:23 PDT 2026
the project "PostGIS".
The branch, stable-3.5 has been updated
       via  f72686cca639ecb373cb82eaeebb3e9ef9022b84 (commit)
       via  244b981b409656fe89abc6998f64f7075b5148ba (commit)
      from  a636b7efccd358acc430d8863159a54800b76079 (commit)
revisions in full, below.
commit f72686cca639ecb373cb82eaeebb3e9ef9022b84
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Fri May 29 10:58:59 2026 -0700
    News item for #5988
diff --git a/NEWS b/NEWS
index b6e81181a..1bbd739c9 100644
--- a/NEWS
+++ b/NEWS
@@ -4,7 +4,7 @@ PostGIS 3.5.7
 * Bug Fixes *
   - Flatgeobuf schema mismatch vulnerability (NeuroWinter)
+  - #5899, pg_upgrade issue for non-standard geography SRID (Paul Ramsey)
 PostGIS 3.5.6
commit 244b981b409656fe89abc6998f64f7075b5148ba
Date:   Fri May 29 16:21:02 2026 +0000
    When doing pg_upgrade on a table with Geography(type, srid)
    column, where the SRID is specified, but not 4326, the SRID
    lookup code will fail during schema transfer as the
    spatial_ref_sys table may be missing and unable to lookup
    the SRID number. This "fix" leans on the fact that most
    SRID numbers in PostGIS are already EPSG numbers so the
    lookup can be skipped most times.
diff --git a/libpgcommon/lwgeom_transform.c b/libpgcommon/lwgeom_transform.c
index 1fe21fa16..97d666508 100644
--- a/libpgcommon/lwgeom_transform.c
+++ b/libpgcommon/lwgeom_transform.c
@@ -176,6 +176,40 @@ GetProjStringsSPI(int32_t srid)
 		elog(ERROR, "Could not connect to database using SPI");
+	 * During pg_upgrade, geography typmod is parsed before spatial_ref_sys
+	 * exists or is populated. Check both conditions via catalog before
+	 * querying the table, to avoid a transaction-aborting error.
+	 * If either check fails, return "EPSG:<srid>" directly so PROJ can
+	 * resolve standard codes from its own database.
+	Oid nsp_oid = POSTGIS_CONSTANTS ? POSTGIS_CONSTANTS->install_nsp_oid : InvalidOid;
+	snprintf(proj_spi_buffer, spibufferlen,
+	         "SELECT 1 FROM pg_class "
+	         "WHERE relname = 'spatial_ref_sys' AND relnamespace = %u",
+	         nsp_oid);
+	spi_result = SPI_execute(proj_spi_buffer, true, 1);
+	bool srs_exists = (spi_result == SPI_OK_SELECT && SPI_processed > 0);
+	bool srs_populated = false;
+	if (srs_exists)
+		         "SELECT 1 FROM %s LIMIT 1",
+		         postgis_spatial_ref_sys());
+		srs_populated = (spi_result == SPI_OK_SELECT && SPI_processed > 0);
+	if (!srs_exists || !srs_populated)
+		char tmp[maxprojlen];
+		snprintf(tmp, maxprojlen, "EPSG:%d", srid);
+		strs.authtext = SPI_pstrdup(tmp);
+		SPI_finish();
+		return strs;
 	static char *proj_str_tmpl =
 	    "SELECT proj4text, auth_name, auth_srid, srtext "
 	    "FROM %s "
Summary of changes:
 NEWS                           |  2 +-
 libpgcommon/lwgeom_transform.c | 34 ++++++++++++++++++++++++++++++++++
 2 files changed, 35 insertions(+), 1 deletion(-)
hooks/post-receive
