[SCM] PostGIS branch master updated. 3.7.0rc1-36-g3fbdf1147
git at osgeo.org
git at osgeo.org
Mon Sep 7 13:14:09 PDT 2026
the project "PostGIS".
via 3fbdf1147ed45c0836e7f29d5aa4e37c3c4cd52e (commit)
from 17189b294f0094a60546c3f94973de6658f2db0b (commit)
revisions in full, below.
commit 3fbdf1147ed45c0836e7f29d5aa4e37c3c4cd52e
Author: Regina Obe <lr at pcorp.us>
Date: Mon Sep 7 16:14:04 2026 -0400
Update docs and pot
diff --git a/NEWS b/NEWS
index 069a05a2d..0a08513f3 100644
--- a/NEWS
+++ b/NEWS
@@ -1,9 +1,10 @@
PostGIS 3.7.0rc2
-2026/xx/xx
+2026/09/07
-This version requires GEOS 3.10+, PostgreSQL 14-19beta1, Proj 6.1+, and libgmp.
+This version requires GEOS 3.10+, PostgreSQL 14-19beta3, Proj 6.1+, and libgmp.
To take advantage of all postgis extension features, GEOS 3.15+ is needed.
To take advantage of all postgis_sfcgal extension features SFCGAL 2.3+ is needed.
+Python 3 is a new requirement to build the documentation.
* Breaking Changes *
@@ -171,9 +172,6 @@ To take advantage of all postgis_sfcgal extension features SFCGAL 2.3+ is needed
GDAL compatibility (Darafei Praliaskouski)
PostGIS 3.7.0rc1
2026/08/24
This version requires GEOS 3.10+, PostgreSQL 14-19beta2, Proj 6.1+, libgmp.
diff --git a/README.postgis b/README.postgis
index 5fe870f4f..5c463f0e5 100644
--- a/README.postgis
+++ b/README.postgis
@@ -2,7 +2,7 @@ PostGIS - Geographic Information Systems Extensions to PostgreSQL
:Version: 3.7.0
-:Date: 2026-09-01
+:Date: 2026-09-07
:Website: https://postgis.net
This distribution contains a module which implements GIS simple features, ties
diff --git a/doc/po/templates/postgis-manual.pot b/doc/po/templates/postgis-manual.pot
index 702dab7ae..5a60449c2 100644
--- a/doc/po/templates/postgis-manual.pot
+++ b/doc/po/templates/postgis-manual.pot
@@ -4714,7 +4714,7 @@ msgstr ""
#. Tag: para
#, no-c-format
msgid ""
-"GEOS geometry library, version &min_geos_version; or greater, but GEOS 3.14+ "
+"GEOS geometry library, version &min_geos_version; or greater, but GEOS 3.15+ "
"is required to take full advantage of all the new functions and features. "
"GEOS is available for download from <link xlink:href=\"https://libgeos.org/"
"\"> https://libgeos.org </link>."
@@ -4723,19 +4723,26 @@ msgstr ""
#. Tag: para
#, no-c-format
msgid ""
-"LibXML2, version 2.5.x or higher. LibXML2 is currently used in some imports "
-"functions (ST_GeomFromGML and ST_GeomFromKML). LibXML2 is available for "
-"download from <link xlink:href=\"https://gitlab.gnome.org/GNOME/libxml2/-/"
-"releases\">https://gitlab.gnome.org/GNOME/libxml2/-/releases</link>."
+"LibXML2. LibXML2 is currently used in some imports functions (ST_GeomFromGML "
+"and ST_GeomFromKML). LibXML2 is available for download from <link xlink:"
+"href=\"https://gitlab.gnome.org/GNOME/libxml2/-/releases\">https://gitlab."
+"gnome.org/GNOME/libxml2/-/releases</link>."
msgstr ""
#. Tag: para
#, no-c-format
msgid ""
-"JSON-C, version 0.9 or higher. JSON-C is currently used to import GeoJSON "
-"via the function ST_GeomFromGeoJson. JSON-C is available for download from "
-"<link xlink:href=\"https://github.com/json-c/json-c/releases\">https://"
-"github.com/json-c/json-c/releases/</link>."
+"Perl is required to build PostGIS. Perl is available for download from <link "
+"xlink:href=\"https://www.perl.org/\">https://www.perl.org/</link>."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"The iconv library is required by the shp2pgsql loader for encoding "
+"conversion. On GNU/Linux systems it is typically provided by libc; on other "
+"platforms you may need a separate <link xlink:href=\"https://www.gnu.org/"
+"software/libiconv/\">libiconv</link> package."
msgstr ""
#. Tag: para
@@ -4744,15 +4751,16 @@ msgid ""
"The GNU Multiple Precision Arithmetic Library (libgmp). Used to control "
"precision of math operations in PostGIS Topology. GMP is available for "
"download from <link xlink:href=\"https://gmplib.org/\">https://gmplib.org/</"
-"link>."
+"link>. It is detected via <command>pkg-config</command> and has no fallback, "
+"so <command>pkg-config</command> must be available for a default build."
msgstr ""
#. Tag: para
#, no-c-format
msgid ""
-"GDAL, version 3+ is preferred. This is required for raster support. <link "
-"xlink:href=\"https://gdal.org/download.html\">https://gdal.org/download."
-"html</link>."
+"GDAL, version 2.4 or higher, is required for raster support. GDAL 3+ is "
+"preferred. <link xlink:href=\"https://gdal.org/download.html\">https://gdal."
+"org/download.html</link>."
msgstr ""
#. Tag: para
@@ -4776,6 +4784,26 @@ msgid ""
"linkend=\"raster_configuration\"/>."
msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"JSON-C. JSON-C is currently used to import GeoJSON via the function "
+"ST_GeomFromGeoJson. JSON-C is available for download from <link xlink:"
+"href=\"https://github.com/json-c/json-c/releases\">https://github.com/json-c/"
+"json-c/releases/</link>. It is enabled by default but optional; if it is not "
+"found configure only warns and the build continues. Disable with <varname>--"
+"without-json</varname>."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"GNU gettext for loader and documentation translation support. It may be "
+"disabled with <varname>--with-gettext=no</varname>. <link xlink:"
+"href=\"https://www.gnu.org/software/gettext/\">https://www.gnu.org/software/"
+"gettext/</link>."
+msgstr ""
#. Tag: para
#, no-c-format
msgid ""
@@ -4786,7 +4814,7 @@ msgstr ""
#. Tag: para
#, no-c-format
msgid ""
-"SFCGAL, 1.4.1 or higher is required, 2.3+ is needed to be able to use all "
+"SFCGAL, 1.3.1 or higher is required, 2.3+ is needed to be able to use all "
"functionality. SFCGAL can be used to provide additional 2D and 3D advanced "
"analysis functions to PostGIS cf <xref linkend=\"reference_sfcgal\"/>. <link "
"xlink:href=\"https://sfcgal.gitlab.io/sfcgal/\">https://sfcgal.gitlab.io/"
@@ -4822,6 +4850,18 @@ msgid ""
"docbook.org/\"> http://www.docbook.org/ </link> ."
msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Python 3 is required to run the manual example tester that generates the "
+"visual examples which the HTML and PDF documentation embed. The examples are "
+"executed against a live PostgreSQL server running the staged PostGIS build "
+"via <command>make -C regress visual-examples</command>; no Python database "
+"driver is required, the tooling talks to the server through the "
+"<command>psql</command> client. Python 3 is available from <link xlink:"
+"href=\"https://www.python.org/\"> https://www.python.org/ </link> ."
+msgstr ""
#. Tag: para
#, no-c-format
msgid ""
@@ -13363,9 +13403,9 @@ msgstr ""
#, no-c-format
msgid ""
"By default, GDAL logging is printed to stderr, and lower level debug "
-"messages are not printed at all. Turning this GUC to true will cause GDAL "
-"logging to be sent into the PostgreSQL logging stream, so you can see more "
-"or less of it by altering the <code>client_min_message</code> PostgreSQL GUC."
+"messages are not printed at all. Turning this GUC to true will cause "
+"detailed GDAL logging to be sent into the PostgreSQL server log. PostgreSQL "
+"clients receive only generic GDAL notice, debug, warning, or error messages."
msgstr ""
#. Tag: title
@@ -15346,8 +15386,8 @@ msgstr ""
#, no-c-format
msgid ""
"Removes a geometry column from a spatial table. Note that schema_name will "
-"need to match the f_table_schema field of the table's row in the "
-"geometry_columns table."
+"need to match the f_table_schema field shown by the "
+"<varname>geometry_columns</varname> view."
msgstr ""
#. Tag: para
@@ -35894,10 +35934,10 @@ msgstr ""
#. Tag: para
#, no-c-format
msgid ""
-"This version requires GEOS 3.10+, PostgreSQL 14-19beta1, Proj 6.1+, libgmp. "
-"To take advantage of all features postgis extension features, GEOS 3.15+ is "
+"This version requires GEOS 3.10+, PostgreSQL 14-19beta3, Proj 6.1+, and "
+"libgmp. To take advantage of all postgis extension features, GEOS 3.15+ is "
"needed. To take advantage of all postgis_sfcgal extension features SFCGAL "
-"2.3+ is needed."
+"2.3+ is needed. Python 3 is a new requirement to build the documentation."
msgstr ""
#. Tag: title
@@ -35967,6 +36007,14 @@ msgid ""
"link>, CG_AlphaShape now returns a MultiPolygon (Jean Felder)"
msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"[docs] Python 3 and an SVG rasterizer (rsvg-convert preferred, "
+"GraphicsMagick or ImageMagick supported) now required for doc building "
+"(Darafei Praliaskouski)"
+msgstr ""
#. Tag: title
#, no-c-format
msgid "New Features"
@@ -36072,22 +36120,6 @@ msgid ""
"Praliaskouski)"
msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"<link xlink:href=\"https://trac.osgeo.org/postgis/ticket/5950\">#5950</"
-"link>, Document POSTGIS_REGRESS_DB_OWNER for sandboxed regression roles "
-"(Darafei Praliaskouski)"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"<link xlink:href=\"https://trac.osgeo.org/postgis/ticket/4332\">#4332</"
-"link>, Clarify the scope of several Function Reference categories (Darafei "
-"Praliaskouski)"
-msgstr ""
#. Tag: para
#, no-c-format
msgid ""
@@ -36096,14 +36128,6 @@ msgid ""
"Praliaskouski)"
msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"<link xlink:href=\"https://trac.osgeo.org/postgis/ticket/5109\">#5109</"
-"link>, Document the meaning of topology.next_left_edge and topology."
-"next_right_edge links (Darafei Praliaskouski)"
-msgstr ""
#. Tag: para
#, no-c-format
msgid ""
@@ -36120,14 +36144,6 @@ msgid ""
"Ramsey)"
msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"<link xlink:href=\"https://trac.osgeo.org/postgis/ticket/6022\">#6022</"
-"link>, Document ST_AsMVTGeom tile-coordinate simplification (Darafei "
-"Praliaskouski)"
-msgstr ""
#. Tag: para
#, no-c-format
msgid ""
@@ -36173,14 +36189,6 @@ msgid ""
msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"[fuzzers] Centralize OSS-Fuzz build/dependency logic in PostGIS scripts, "
-"prefer requested CXX over pg_config --cc for internal C++ checks, and make "
-"fuzzer linking/runtime dependency packaging portable (Darafei Praliaskouski)"
-msgstr ""
#. Tag: title
#, no-c-format
msgid "Enhancements"
@@ -36210,6 +36218,14 @@ msgid ""
"liblwgeom header (Darafei Praliaskouski)"
msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<link xlink:href=\"https://trac.osgeo.org/postgis/ticket/3776\">#3776</"
+"link>, [raster] Keep distinct 32-bit integer pixel values separate in "
+"ST_DumpAsPolygons (Darafei Praliaskouski)"
+msgstr ""
#. Tag: para
#, no-c-format
msgid ""
@@ -36236,13 +36252,6 @@ msgid ""
"Praliaskouski)"
msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"<link xlink:href=\"https://trac.osgeo.org/postgis/ticket/2898\">#2898</"
-"link>, Document SQL function cost tiers for contributors"
-msgstr ""
#. Tag: para
#, no-c-format
msgid ""
@@ -36259,16 +36268,6 @@ msgid ""
"collapsed elements (Sandro Santilli)"
msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"<link xlink:href=\"https://trac.osgeo.org/postgis/ticket/3743\">#3743</"
-"link>, <link xlink:href=\"https://trac.osgeo.org/postgis/"
-"ticket/4385\">#4385</link>, [raster loader] Document raster2pgsql -s "
-"FROM_SRID:SRID reprojection support and clarify index creation timing for "
-"append loads (Darafei Praliaskouski)"
-msgstr ""
#. Tag: para
#, no-c-format
msgid ""
@@ -36285,22 +36284,6 @@ msgid ""
"GeometryCollections (Darafei Praliaskouski)"
msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"<link xlink:href=\"https://trac.osgeo.org/postgis/ticket/5532\">#5532</"
-"link>, Validate the manual against DocBook XMLSchema in check-xml (Darafei "
-"Praliaskouski)"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"<link xlink:href=\"https://trac.osgeo.org/postgis/ticket/6087\">#6087</"
-"link>, Add a repository-owned CI status checker and static dashboard "
-"generator (Darafei Praliaskouski)"
-msgstr ""
#. Tag: para
#, no-c-format
msgid ""
@@ -36333,13 +36316,6 @@ msgid ""
msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"<link xlink:href=\"https://trac.osgeo.org/postgis/ticket/2386\">#2386</"
-"link>, Add raster2pgsql man page (Darafei Praliaskouski)"
-msgstr ""
#. Tag: para
#, no-c-format
msgid ""
@@ -36367,31 +36343,6 @@ msgid ""
"scripts are newer than core scripts (Darafei Praliaskouski)"
msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"<link xlink:href=\"https://trac.osgeo.org/postgis/ticket/5593\">#5593</"
-"link>, Docs: render manual images with GraphicsMagick without temporary "
-"files, enabling parallel builds, keeping ImageMagick fallbacks working, and "
-"documenting the generator workflow for contributors (Darafei Praliaskouski)"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"<link xlink:href=\"https://trac.osgeo.org/postgis/ticket/5645\">#5645</"
-"link>, Docs: keep code operators ("=>") intact in translated "
-"manuals by enforcing verbatim CSS (Darafei Praliaskouski)"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"<link xlink:href=\"https://trac.osgeo.org/postgis/ticket/1408\">#1408</"
-"link>, Docs: flatten transparent manual images onto white backgrounds for "
-"PDF builds while keeping HTML images transparent (Darafei Praliaskouski)"
-msgstr ""
#. Tag: para
#, no-c-format
msgid ""
@@ -36400,14 +36351,6 @@ msgid ""
"Praliaskouski)"
msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"<link xlink:href=\"https://trac.osgeo.org/postgis/ticket/1705\">#1705</"
-"link>, Infer constraint metadata for direct view and materialized view "
-"geometry columns (Darafei Praliaskouski)"
-msgstr ""
#. Tag: para
#, no-c-format
msgid ""
@@ -36416,6 +36359,15 @@ msgid ""
"callbacks (Darafei Praliaskouski)"
msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<link xlink:href=\"https://trac.osgeo.org/postgis/ticket/6073\">#6073</"
+"link>, <link xlink:href=\"https://trac.osgeo.org/postgis/"
+"ticket/6074\">#6074</link>, Stabilize geography LRS endpoint interpolation "
+"and pole centroid regressions on 32-bit systems (Darafei Praliaskouski)"
+msgstr ""
#. Tag: para
#, no-c-format
msgid ""
@@ -36424,6 +36376,255 @@ msgid ""
msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<link xlink:href=\"https://trac.osgeo.org/postgis/ticket/4616\">#4616</"
+"link>, Detect pgsql2shp query keywords case-insensitively (Darafei "
+"Praliaskouski)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<link xlink:href=\"https://trac.osgeo.org/postgis/ticket/1986\">#1986</"
+"link>, ST_GeomFromGML support for GML ArcString and curved polygon rings "
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<link xlink:href=\"https://trac.osgeo.org/postgis/ticket/4749\">#4749</"
+"link>, Use point-in-polygon predicate fast paths for point-only "
+"GeometryCollections, including ST_Disjoint (Darafei Praliaskouski)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<link xlink:href=\"https://trac.osgeo.org/postgis/ticket/3676\">#3676</"
+"link>, Mark geometry and geography btree comparison support functions as "
+"leakproof (Darafei Praliaskouski)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<link xlink:href=\"https://github.com/postgis/postgis/pull/875\">GH-875</"
+"link>, Allow ST_OrderingEquals joins to use hash and merge join plans "
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<link xlink:href=\"https://trac.osgeo.org/postgis/ticket/1168\">#1168</"
+"link>, [raster] Support curved geometry inputs in ST_AsRaster (Darafei "
+"Praliaskouski)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<link xlink:href=\"https://trac.osgeo.org/postgis/ticket/1416\">#1416</"
+"link>, ST_AsX3D outputs NURBSCURVE as X3D NurbsCurve and linearizes other "
+"curve geometries (Darafei Praliaskouski)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<link xlink:href=\"https://trac.osgeo.org/postgis/ticket/3705\">#3705</"
+"link>, ST_AsX3D outputs valid coordinate nodes for 2D multi-geometries and "
+"GeometryCollections (Darafei Praliaskouski)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<link xlink:href=\"https://gitea.osgeo.org/postgis/postgis/"
+"pulls/484\">GT-484</link>, Use column-level SELECT privileges for metadata "
+"views (Arthur Bazin)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<link xlink:href=\"https://trac.osgeo.org/postgis/ticket/1408\">#1408</"
+"ticket/2386\">#2386</link>, <link xlink:href=\"https://trac.osgeo.org/"
+"postgis/ticket/2557\">#2557</link>, <link xlink:href=\"https://trac.osgeo."
+"org/postgis/ticket/2805\">#2805</link>, <link xlink:href=\"https://trac."
+"osgeo.org/postgis/ticket/2898\">#2898</link>, <link xlink:href=\"https://"
+"trac.osgeo.org/postgis/ticket/3743\">#3743</link>, <link xlink:"
+"href=\"https://trac.osgeo.org/postgis/ticket/4323\">#4323</link>, <link "
+"xlink:href=\"https://trac.osgeo.org/postgis/ticket/4332\">#4332</link>, "
+"<link xlink:href=\"https://trac.osgeo.org/postgis/ticket/4385\">#4385</"
+"ticket/5109\">#5109</link>, <link xlink:href=\"https://trac.osgeo.org/"
+"postgis/ticket/5532\">#5532</link>, <link xlink:href=\"https://trac.osgeo."
+"org/postgis/ticket/5593\">#5593</link>, <link xlink:href=\"https://trac."
+"osgeo.org/postgis/ticket/5638\">#5638</link>, <link xlink:href=\"https://"
+"trac.osgeo.org/postgis/ticket/5645\">#5645</link>, <link xlink:"
+"href=\"https://trac.osgeo.org/postgis/ticket/5950\">#5950</link>, <link "
+"xlink:href=\"https://trac.osgeo.org/postgis/ticket/6022\">#6022</link>, "
+"<link xlink:href=\"https://trac.osgeo.org/postgis/ticket/6082\">#6082</"
+"link>, <link xlink:href=\"https://github.com/postgis/postgis/"
+"pull/1161\">GH-1161</link>, <link xlink:href=\"https://gitea.osgeo.org/"
+"postgis/postgis/pulls/584\">GT-584</link>, Numerous doc enhancements "
+msgstr ""
+#. Tag: title
+#, no-c-format
+msgid "Bug Fixes"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<link xlink:href=\"https://github.com/postgis/postgis/pull/1175\">GH-1175</"
+"link>, Guard missing operands before reading node tags in spatial "
+"selectivity estimation (Maksim Korotkov)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<link xlink:href=\"https://trac.osgeo.org/postgis/ticket/6118\">#6118</"
+"link>, Reject empty geometry type modifiers without an out-of-bounds read "
+"(Egor Ivkov)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Fix WKB and TWKB parser resource exhaustion on malformed input (Darafei "
+"Praliaskouski)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<link xlink:href=\"https://trac.osgeo.org/postgis/ticket/6038\">#6038</"
+"link>, Avoid stale relation lookups in geometry_columns after topology "
+"objects are dropped (Darafei Praliaskouski)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<link xlink:href=\"https://trac.osgeo.org/postgis/ticket/5487\">#5487</"
+"link>, Improve error detail for repeated upgrades after an incomplete "
+"deprecated-function cleanup (Darafei Praliaskouski)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<link xlink:href=\"https://trac.osgeo.org/postgis/ticket/5975\">#5975</"
+"link>, Initialize skipped union-find cluster ids deterministically (Darafei "
+"Praliaskouski)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<link xlink:href=\"https://trac.osgeo.org/postgis/ticket/5904\">#5904</"
+"link>, [topology] Avoid MinGW format warnings when logging topology ids "
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<link xlink:href=\"https://github.com/postgis/postgis/pull/888\">GH-888</"
+"link>, [sfcgal] Avoid stale detoasted geometry access in CG_Visibility empty-"
+"input handling for SFCGAL < 2.2 (Darafei Praliaskouski)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<link xlink:href=\"https://trac.osgeo.org/postgis/ticket/3179\">#3179</"
+"link>, Mark truncated libpgcommon PostgreSQL messages instead of silently "
+"dropping the tail (Darafei Praliaskouski)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<link xlink:href=\"https://trac.osgeo.org/postgis/ticket/6003\">#6003</"
+"link>, Avoid size_t formats in liblwgeom logging/error wrappers for MinGW "
+"builds (Darafei Praliaskouski)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<link xlink:href=\"https://github.com/postgis/postgis/pull/886\">GH-886</"
+"link>, ST_ClusterRelateWin validates NULL relate matrices before detoasting "
+"them (Darafei Praliaskouski)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<link xlink:href=\"https://github.com/postgis/postgis/pull/889\">GH-889</"
+"link>, ST_Relate pattern inversion avoids out-of-bounds access on short "
+"DE-9IM patterns (Darafei Praliaskouski)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<link xlink:href=\"https://github.com/postgis/postgis/pull/890\">GH-890</"
+"link>, Avoid GIDX BRIN summary merges across mismatched dimensions (Darafei "
+"Praliaskouski)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<link xlink:href=\"https://trac.osgeo.org/postgis/ticket/5959\">#5959</"
+"link>, Prevent histogram target overflow when analysing massive tables "
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<link xlink:href=\"https://trac.osgeo.org/postgis/ticket/6080\">#6080</"
+"link>, Avoid out-of-bounds hex WKB lookup for high-bit input bytes (Darafei "
+"Praliaskouski)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<link xlink:href=\"https://trac.osgeo.org/postgis/ticket/4828\">#4828</"
+"link>, geometry_columns handles NOT VALID SRID checks without errors "
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<link xlink:href=\"https://trac.osgeo.org/postgis/ticket/6048\">#6048</"
+"link>, [raster] ST_Clip no longer crashes when clipping sparse band "
+"selections (Darafei Praliaskouski)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<link xlink:href=\"https://github.com/postgis/postgis/pull/894\">GH-894</"
+"link>, [raster] Fix Float16 import, mixed nodata warping, band replacement "
+"cleanup, GDAL credential redaction, and Python GDAL compatibility (Darafei "
+"Praliaskouski)"
+msgstr ""
#. Tag: title
#, no-c-format
msgid "Reporting Problems"
@@ -38519,10 +38720,10 @@ msgstr ""
#. Tag: para
#, no-c-format
msgid ""
-"Although the old constraint-based method is still supported, direct pass-"
-"through view columns register correctly in <varname>geometry_columns</"
-"varname> for both typmod-based and constraint-based source columns. In this "
-"example we define a column using typmod and another using constraints."
+"Although the old-constraint based method is still supported, a constraint-"
+"based geometry column used directly in a view, will not register correctly "
+"in geometry_columns, as will a typmod one. In this example we define a "
+"column using typmod and another using constraints."
msgstr ""
#. Tag: para
@@ -38545,16 +38746,15 @@ msgstr ""
#. Tag: para
#, no-c-format
msgid ""
-"Both the typmod based geom view column and the direct constraint based view "
-"column register correctly."
+"The typmod based geom view column registers correctly, but the constraint "
+"based one does not."
msgstr ""
#. Tag: para
#, no-c-format
msgid ""
-"If the view applies a spatial function to the geometry, such as "
-"<function>ST_Transform</function>, you still need to cast the transformed "
-"column explicitly so the view can expose the correct type and SRID:"
+"This may change in future versions of PostGIS, but for now to force the "
+"constraint-based view column to register correctly, you need to do this:"
msgstr ""
#. Tag: title
diff --git a/doc/release_notes.xml b/doc/release_notes.xml
index 3958a7e9f..2c134e4ae 100644
--- a/doc/release_notes.xml
+++ b/doc/release_notes.xml
@@ -4,8 +4,11 @@
<section xml:id="release_notes_3_7_0">
<title>PostGIS 3.7.0</title>
<subtitle>2026/xx/xx</subtitle>
- <para>This version requires GEOS 3.10+, PostgreSQL 14-19beta2, Proj 6.1+, libgmp. To take advantage of all features postgis extension features, GEOS 3.15+ is needed. To take advantage of all postgis_sfcgal extension features SFCGAL 2.3+ is needed.</para>
- <simplesect>
+ <para>This version requires GEOS 3.10+, PostgreSQL 14-19beta3, Proj 6.1+, and libgmp.
+ To take advantage of all postgis extension features, GEOS 3.15+ is needed.
+ To take advantage of all postgis_sfcgal extension features SFCGAL 2.3+ is needed.
+ Python 3 is a new requirement to build the documentation.</para>
+ <simplesect>
<title>Breaking Changes</title>
<para><link xlink:href="https://trac.osgeo.org/postgis/ticket/5688">#5688</link>, [topology] topology building functions now interpret tolerance 0 (old default) to really mean 0 and want -1 (new default) to mean "use topology precision" (Sandro Santilli)</para>
<para><link xlink:href="https://trac.osgeo.org/postgis/ticket/6024">#6024</link>, Remove support for PostgreSQL 12 and 13 (Regina Obe)</para>
@@ -15,6 +18,7 @@
<para><link xlink:href="https://trac.osgeo.org/postgis/ticket/6079">#6079</link>, Remove support for GEOS < 3.10 (Sandro Santilli)</para>
<para><link xlink:href="https://trac.osgeo.org/postgis/ticket/1793">#1793</link>, Remove ST_MemCollect aggregate (Darafei Praliaskouski)</para>
<para><link xlink:href="https://github.com/postgis/postgis/pull/848">GH-848</link>, CG_AlphaShape now returns a MultiPolygon (Jean Felder)</para>
+ <para>[docs] Python 3 and an SVG rasterizer (rsvg-convert preferred, GraphicsMagick or ImageMagick supported) now required for doc building (Darafei Praliaskouski)</para>
</simplesect>
<simplesect>
<title>New Features</title>
@@ -31,51 +35,71 @@
<para><link xlink:href="https://trac.osgeo.org/postgis/ticket/5992">#5992</link>, Optimize GiST index for repeated edge subdivision in topology (Darafei Praliaskouski)</para>
<para><link xlink:href="https://trac.osgeo.org/postgis/ticket/5702">#5702</link>, Allow the compiler to detect the parallelism -flto=auto (Darafei Praliaskouski)</para>
<para><link xlink:href="https://trac.osgeo.org/postgis/ticket/4798">#4798</link>, ST_AsGeoJSON warns about duplicate property keys (Darafei Praliaskouski)</para>
- <para><link xlink:href="https://trac.osgeo.org/postgis/ticket/5950">#5950</link>, Document POSTGIS_REGRESS_DB_OWNER for sandboxed regression roles (Darafei Praliaskouski)</para>
- <para><link xlink:href="https://trac.osgeo.org/postgis/ticket/4332">#4332</link>, Clarify the scope of several Function Reference categories (Darafei Praliaskouski)</para>
<para><link xlink:href="https://trac.osgeo.org/postgis/ticket/4222">#4222</link>, [raster] ST_DumpAsPolygons honours PostgreSQL interrupts (Darafei Praliaskouski)</para>
- <para><link xlink:href="https://trac.osgeo.org/postgis/ticket/5109">#5109</link>, Document the meaning of topology.next_left_edge and topology.next_right_edge links (Darafei Praliaskouski)</para>
<para><link xlink:href="https://trac.osgeo.org/postgis/ticket/5889">#5889</link>, [topology] Include representative locations in topology build errors (Darafei Praliaskouski)</para>
<para><link xlink:href="https://trac.osgeo.org/postgis/ticket/2614">#2614</link>, Use GEOSPreparedDistance and caching to accelerate ST_DWithin (Paul Ramsey)</para>
- <para><link xlink:href="https://trac.osgeo.org/postgis/ticket/6022">#6022</link>, Document ST_AsMVTGeom tile-coordinate simplification (Darafei Praliaskouski)</para>
<para><link xlink:href="https://github.com/postgis/postgis/pull/839">GH-839</link>, ST_Multi support for TIN and surfaces (Loïc Bartoletti)</para>
<para><link xlink:href="https://trac.osgeo.org/postgis/ticket/4398">#4398</link>, Add ST_CatmullSmoothing smoothes but retains original vertices (Paul Ramsey)</para>
<para><link xlink:href="https://trac.osgeo.org/postgis/ticket/4560">#4560</link>, ST_3DInterpolatePoint for M interpolation from XYZ inputs (Paul Ramsey)</para>
<para><link xlink:href="https://trac.osgeo.org/postgis/ticket/1291">#1291</link>, ST_MakePolygon support for curved rings (Darafei Praliaskouski)</para>
<para><link xlink:href="https://gitea.osgeo.org/postgis/postgis/pulls/270">GT-270</link>, Add NURBSCurve (Loïc Bartoletti)</para>
<para><link xlink:href="https://trac.osgeo.org/postgis/ticket/2863">#2863</link>, Add ST_XSize, ST_YSize, ST_ZSize, and ST_MSize dimension helpers (Darafei Praliaskouski)</para>
- <para>[fuzzers] Centralize OSS-Fuzz build/dependency logic in PostGIS scripts, prefer requested CXX over pg_config --cc for internal C++ checks, and make fuzzer linking/runtime dependency packaging portable (Darafei Praliaskouski)</para>
</simplesect>
<simplesect>
<title>Enhancements</title>
<para><link xlink:href="https://trac.osgeo.org/postgis/ticket/2045">#2045</link>, pgsql2shp query dumps no longer require temporary table privileges (Darafei Praliaskouski)</para>
<para><link xlink:href="https://trac.osgeo.org/postgis/ticket/1577">#1577</link>, [loader] Report unsupported .zip archive input before trying to open shapefile sidecar files (Darafei Praliaskouski)</para>
<para><link xlink:href="https://trac.osgeo.org/postgis/ticket/3158">#3158</link>, Move geometry and geography typmod bit helpers out of the public liblwgeom header (Darafei Praliaskouski)</para>
+ <para><link xlink:href="https://trac.osgeo.org/postgis/ticket/3776">#3776</link>, [raster] Keep distinct 32-bit integer pixel values separate in ST_DumpAsPolygons (Darafei Praliaskouski)</para>
<para><link xlink:href="https://trac.osgeo.org/postgis/ticket/4678">#4678</link>, [raster] Move st_sum4ma neighborhood callback to C (Darafei Praliaskouski)</para>
<para><link xlink:href="https://trac.osgeo.org/postgis/ticket/2116">#2116</link>, [raster] Add ST_Value nearest-neighbor boundary options (Darafei Praliaskouski)</para>
<para><link xlink:href="https://trac.osgeo.org/postgis/ticket/2804">#2804</link>, <link xlink:href="https://trac.osgeo.org/postgis/ticket/4315">#4315</link>, [raster] Support two-argument ST_MapAlgebra callbacks and pass callback call data as actual arguments (Darafei Praliaskouski)</para>
- <para><link xlink:href="https://trac.osgeo.org/postgis/ticket/2898">#2898</link>, Document SQL function cost tiers for contributors</para>
<para><link xlink:href="https://trac.osgeo.org/postgis/ticket/6062">#6062</link>, [topology] Stop using recursive snapping, for improved robustness (Sandro Santilli)</para>
<para><link xlink:href="https://trac.osgeo.org/postgis/ticket/6065">#6065</link>, Improved winding order computation robustness for rings having collapsed elements (Sandro Santilli)</para>
- <para><link xlink:href="https://trac.osgeo.org/postgis/ticket/3743">#3743</link>, <link xlink:href="https://trac.osgeo.org/postgis/ticket/4385">#4385</link>, [raster loader] Document raster2pgsql -s FROM_SRID:SRID reprojection support and clarify index creation timing for append loads (Darafei Praliaskouski)</para>
<para><link xlink:href="https://trac.osgeo.org/postgis/ticket/2137">#2137</link>, [raster] Reuse matching source raster overviews in raster2pgsql -l (Darafei Praliaskouski)</para>
<para><link xlink:href="https://trac.osgeo.org/postgis/ticket/4749">#4749</link>, Use point-in-polygon predicate fast paths for point-only GeometryCollections (Darafei Praliaskouski)</para>
- <para><link xlink:href="https://trac.osgeo.org/postgis/ticket/5532">#5532</link>, Validate the manual against DocBook XMLSchema in check-xml (Darafei Praliaskouski)</para>
- <para><link xlink:href="https://trac.osgeo.org/postgis/ticket/6087">#6087</link>, Add a repository-owned CI status checker and static dashboard generator (Darafei Praliaskouski)</para>
<para><link xlink:href="https://trac.osgeo.org/postgis/ticket/2807">#2807</link>, [raster] Preserve missing NODATA values in ST_MapAlgebra outputs (Darafei Praliaskouski)</para>
<para><link xlink:href="https://trac.osgeo.org/postgis/ticket/2832">#2832</link>, [raster] Avoid padding single-tile raster2pgsql overviews when padding is not requested (Darafei Praliaskouski)</para>
<para><link xlink:href="https://trac.osgeo.org/postgis/ticket/2623">#2623</link>, Generate a pgsql2shp GID field when exporting geometry-only shapefiles (Darafei Praliaskouski)</para>
<para><link xlink:href="https://trac.osgeo.org/postgis/ticket/2850">#2850</link>, Preserve pgsql2shp numeric precision and scale in DBF metadata (Darafei Praliaskouski)</para>
- <para><link xlink:href="https://trac.osgeo.org/postgis/ticket/2386">#2386</link>, Add raster2pgsql man page (Darafei Praliaskouski)</para>
<para>Build PostgreSQL extension modules with `-fno-semantic-interposition` when available so LTO can optimize same-DSO calls to exported PostGIS entry points directly instead of routing through the module PLT; in a local PostgreSQL 18 `pgbench` microbenchmark over 100k four-point groups this reduced `ST_Collect` aggregate latency by about 4% (Darafei Praliaskouski)</para>
<para><link xlink:href="https://trac.osgeo.org/postgis/ticket/5973">#5973</link>, Install PostGIS utilities under `pg_config --bindir` by default and document `pg_config`-derived install paths more accurately (Darafei Praliaskouski)</para>
<para><link xlink:href="https://trac.osgeo.org/postgis/ticket/2808">#2808</link>, Clarify postgis_full_version() output when installed component scripts are newer than core scripts (Darafei Praliaskouski)</para>
- <para><link xlink:href="https://trac.osgeo.org/postgis/ticket/5593">#5593</link>, Docs: render manual images with GraphicsMagick without temporary files, enabling parallel builds, keeping ImageMagick fallbacks working, and documenting the generator workflow for contributors (Darafei Praliaskouski)</para>
- <para><link xlink:href="https://trac.osgeo.org/postgis/ticket/5645">#5645</link>, Docs: keep code operators ("=>") intact in translated manuals by enforcing verbatim CSS (Darafei Praliaskouski)</para>
- <para><link xlink:href="https://trac.osgeo.org/postgis/ticket/1408">#1408</link>, Docs: flatten transparent manual images onto white backgrounds for PDF builds while keeping HTML images transparent (Darafei Praliaskouski)</para>
<para><link xlink:href="https://trac.osgeo.org/postgis/ticket/2838">#2838</link>, Emit valid X3D Coordinate nodes for 2D polygon output (Darafei Praliaskouski)</para>
<para><link xlink:href="https://github.com/postgis/postgis/pull/899">GH-899</link>, [raster] Honor PostgreSQL interrupts in long-running GDAL progress callbacks (Darafei Praliaskouski)</para>
+ <para><link xlink:href="https://trac.osgeo.org/postgis/ticket/6073">#6073</link>, <link xlink:href="https://trac.osgeo.org/postgis/ticket/6074">#6074</link>, Stabilize geography LRS endpoint interpolation and pole centroid regressions on 32-bit systems (Darafei Praliaskouski)</para>
<para><link xlink:href="https://trac.osgeo.org/postgis/ticket/2583">#2583</link>, Preserve Z/ZM dimensional qualifiers in ST_AsEWKT output for TIN (Darafei Praliaskouski)</para>
+ <para><link xlink:href="https://trac.osgeo.org/postgis/ticket/4616">#4616</link>, Detect pgsql2shp query keywords case-insensitively (Darafei Praliaskouski)</para>
+ <para><link xlink:href="https://trac.osgeo.org/postgis/ticket/1986">#1986</link>, ST_GeomFromGML support for GML ArcString and curved polygon rings (Darafei Praliaskouski)</para>
+ <para><link xlink:href="https://trac.osgeo.org/postgis/ticket/4749">#4749</link>, Use point-in-polygon predicate fast paths for point-only GeometryCollections, including ST_Disjoint (Darafei Praliaskouski)</para>
+ <para><link xlink:href="https://trac.osgeo.org/postgis/ticket/3676">#3676</link>, Mark geometry and geography btree comparison support functions as leakproof (Darafei Praliaskouski)</para>
+ <para><link xlink:href="https://github.com/postgis/postgis/pull/875">GH-875</link>, Allow ST_OrderingEquals joins to use hash and merge join plans (Darafei Praliaskouski)</para>
+ <para><link xlink:href="https://trac.osgeo.org/postgis/ticket/1168">#1168</link>, [raster] Support curved geometry inputs in ST_AsRaster (Darafei Praliaskouski)</para>
+ <para><link xlink:href="https://trac.osgeo.org/postgis/ticket/1416">#1416</link>, ST_AsX3D outputs NURBSCURVE as X3D NurbsCurve and linearizes other curve geometries (Darafei Praliaskouski)</para>
+ <para><link xlink:href="https://trac.osgeo.org/postgis/ticket/3705">#3705</link>, ST_AsX3D outputs valid coordinate nodes for 2D multi-geometries and GeometryCollections (Darafei Praliaskouski)</para>
+ <para><link xlink:href="https://gitea.osgeo.org/postgis/postgis/pulls/484">GT-484</link>, Use column-level SELECT privileges for metadata views (Arthur Bazin)</para>
+ <para><link xlink:href="https://trac.osgeo.org/postgis/ticket/1408">#1408</link>, <link xlink:href="https://trac.osgeo.org/postgis/ticket/2386">#2386</link>, <link xlink:href="https://trac.osgeo.org/postgis/ticket/2557">#2557</link>, <link xlink:href="https://trac.osgeo.org/postgis/ticket/2805">#2805</link>, <link xlink:href="https://trac.osgeo.org/postgis/ticket/2898">#2898</link>, <link xlink:href="https://trac.osgeo.org/postgis/ticket/3743">#3743</link>, <link xlink:href="https://trac.osgeo.org/postgis/ticket/4323">#4323</link>, <link xlink:href="https://trac.osgeo.org/postgis/ticket/4332">#4332</link>, <link xlink:href="https://trac.osgeo.org/postgis/ticket/4385">#4385</link>, <link xlink:href="https://trac.osgeo.org/postgis/ticket/5109">#5109</link>, <link xlink:href="https://trac.osgeo.org/postgis/ticket/5532">#5532</link>, <link xlink:href="https://trac.osgeo.org/postgis/ticket/5593">#5593</link>, <link xlink:href="https://trac.osgeo.org/postgis/ticket/5638">#5638</link
>, <link xlink:href="https://trac.osgeo.org/postgis/ticket/5645">#5645</link>, <link xlink:href="https://trac.osgeo.org/postgis/ticket/5950">#5950</link>, <link xlink:href="https://trac.osgeo.org/postgis/ticket/6022">#6022</link>, <link xlink:href="https://trac.osgeo.org/postgis/ticket/6082">#6082</link>, <link xlink:href="https://github.com/postgis/postgis/pull/1161">GH-1161</link>, <link xlink:href="https://gitea.osgeo.org/postgis/postgis/pulls/584">GT-584</link>, Numerous doc enhancements (Darafei Praliaskouski)</para>
+ </simplesect>
+ <simplesect>
+ <title>Bug Fixes</title>
+ <para><link xlink:href="https://github.com/postgis/postgis/pull/1175">GH-1175</link>, Guard missing operands before reading node tags in spatial selectivity estimation (Maksim Korotkov)</para>
+ <para><link xlink:href="https://trac.osgeo.org/postgis/ticket/6118">#6118</link>, Reject empty geometry type modifiers without an out-of-bounds read (Egor Ivkov)</para>
+ <para>Fix WKB and TWKB parser resource exhaustion on malformed input (Darafei Praliaskouski)</para>
+ <para><link xlink:href="https://trac.osgeo.org/postgis/ticket/6038">#6038</link>, Avoid stale relation lookups in geometry_columns after topology objects are dropped (Darafei Praliaskouski)</para>
+ <para><link xlink:href="https://trac.osgeo.org/postgis/ticket/5487">#5487</link>, Improve error detail for repeated upgrades after an incomplete deprecated-function cleanup (Darafei Praliaskouski)</para>
+ <para><link xlink:href="https://trac.osgeo.org/postgis/ticket/5975">#5975</link>, Initialize skipped union-find cluster ids deterministically (Darafei Praliaskouski)</para>
+ <para><link xlink:href="https://trac.osgeo.org/postgis/ticket/5904">#5904</link>, [topology] Avoid MinGW format warnings when logging topology ids (Darafei Praliaskouski)</para>
+ <para><link xlink:href="https://github.com/postgis/postgis/pull/888">GH-888</link>, [sfcgal] Avoid stale detoasted geometry access in CG_Visibility empty-input handling for SFCGAL < 2.2 (Darafei Praliaskouski)</para>
+ <para><link xlink:href="https://trac.osgeo.org/postgis/ticket/3179">#3179</link>, Mark truncated libpgcommon PostgreSQL messages instead of silently dropping the tail (Darafei Praliaskouski)</para>
+ <para><link xlink:href="https://trac.osgeo.org/postgis/ticket/6003">#6003</link>, Avoid size_t formats in liblwgeom logging/error wrappers for MinGW builds (Darafei Praliaskouski)</para>
+ <para><link xlink:href="https://github.com/postgis/postgis/pull/886">GH-886</link>, ST_ClusterRelateWin validates NULL relate matrices before detoasting them (Darafei Praliaskouski)</para>
+ <para><link xlink:href="https://github.com/postgis/postgis/pull/889">GH-889</link>, ST_Relate pattern inversion avoids out-of-bounds access on short DE-9IM patterns (Darafei Praliaskouski)</para>
+ <para><link xlink:href="https://github.com/postgis/postgis/pull/890">GH-890</link>, Avoid GIDX BRIN summary merges across mismatched dimensions (Darafei Praliaskouski)</para>
+ <para><link xlink:href="https://trac.osgeo.org/postgis/ticket/5959">#5959</link>, Prevent histogram target overflow when analysing massive tables (Darafei Praliaskouski)</para>
+ <para><link xlink:href="https://trac.osgeo.org/postgis/ticket/6080">#6080</link>, Avoid out-of-bounds hex WKB lookup for high-bit input bytes (Darafei Praliaskouski)</para>
+ <para><link xlink:href="https://trac.osgeo.org/postgis/ticket/4828">#4828</link>, geometry_columns handles NOT VALID SRID checks without errors (Darafei Praliaskouski)</para>
+ <para><link xlink:href="https://trac.osgeo.org/postgis/ticket/6048">#6048</link>, [raster] ST_Clip no longer crashes when clipping sparse band selections (Darafei Praliaskouski)</para>
+ <para><link xlink:href="https://github.com/postgis/postgis/pull/894">GH-894</link>, [raster] Fix Float16 import, mixed nodata warping, band replacement cleanup, GDAL credential redaction, and Python GDAL compatibility (Darafei Praliaskouski)</para>
</simplesect>
</section>
</appendix>
Summary of changes:
NEWS | 8 +-
README.postgis | 2 +-
doc/po/templates/postgis-manual.pot | 460 ++++++++++++++++++++++++++----------
doc/release_notes.xml | 54 +++--
4 files changed, 373 insertions(+), 151 deletions(-)
hooks/post-receive
