[SCM] PostGIS branch master updated. 3.7.0rc1-42-g8614c07a4
git at osgeo.org
git at osgeo.org
Mon Sep 7 18:43:17 PDT 2026
the project "PostGIS".
via 8614c07a40178981ea16e4ecf4be85d0156ccc17 (commit)
via d9760cc174776ba7abe72572709ee84ff529239e (commit)
via 33bc17e7c8ef88150a624ae11c30013b9a016297 (commit)
via 748d1018fdf67b183722f801b848727faccb3fde (commit)
from 54374cbf25fe631fc9f889ed854affbe46434f6d (commit)
revisions in full, below.
commit 8614c07a40178981ea16e4ecf4be85d0156ccc17
Author: Regina Obe <lr at pcorp.us>
Date: Mon Sep 7 21:40:13 2026 -0400
Don't give a confusing error when visual-examples has not been run yet
Give a simple note that it needs to be run to build docs and then stop
Also note in the NEWS that visual-examples is a requirement for doc building
Closes #6124 for PostGIS 3.7.0
diff --git a/NEWS b/NEWS
index 0a08513f3..5443b197a 100644
--- a/NEWS
+++ b/NEWS
@@ -6,6 +6,12 @@ To take advantage of all postgis extension features, GEOS 3.15+ is needed.
To take advantage of all postgis_sfcgal extension features SFCGAL 2.3+ is needed.
Python 3 is a new requirement to build the documentation.
+To build docs, first run visual examples and make sure you have a running
+PostgreSQL instance.
+`make -C regress visual-examples`
* Breaking Changes *
- #5688, [topology] topology building functions now interpret tolerance 0
diff --git a/doc/Makefile.in b/doc/Makefile.in
index 7353f9a51..a0e186e3b 100644
--- a/doc/Makefile.in
+++ b/doc/Makefile.in
@@ -548,7 +548,7 @@ $(html_builddir)/postgis$(DOCSUFFIX).html: postgis-out.xml Makefile $(HTML_DOCBO
-postgis-${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}.${POSTGIS_MICRO_VERSION}$(DOCSUFFIX).pdf: postgis-out.xml $(abs_srcdir)/texstyle-common.sty $(abs_srcdir)/texstyle.sty $(POSTGIS_DBLATEX_BLOCK_LABELS_XSL) $(POSTGIS_HTML_BLOCK_LABELS_XSL) $(POSTGIS_BLOCK_LABELS_COMMON_XSL) $(visual_examples_inputs) | images pdf-images
+postgis-${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}.${POSTGIS_MICRO_VERSION}$(DOCSUFFIX).pdf: postgis-out.xml $(abs_srcdir)/texstyle-common.sty $(abs_srcdir)/texstyle.sty $(POSTGIS_DBLATEX_BLOCK_LABELS_XSL) $(POSTGIS_HTML_BLOCK_LABELS_XSL) $(POSTGIS_BLOCK_LABELS_COMMON_XSL) $(visual_examples_inputs) | visual-examples images pdf-images
ifeq ($(DBLATEX),)
@echo
@echo "configure was unable to find the 'dblatex' utility program."
@@ -623,9 +623,9 @@ images images-install images-uninstall images-clean:
$(MAKE) -C $(images_builddir) $@
visual-examples:
- $(MAKE) -C $(images_builddir) visual-examples-check
+ @$(if $(shell test -s '$(visual_examples_manifest)' && echo ok),true,$(error Visual examples are missing. Run 'make -C regress visual-examples' first.))
-pdf-images: images
+pdf-images: visual-examples images
$(MAKE) -C $(images_builddir) $@ PDF_IMAGES_BUILD_DIR="$(pdf_images_builddir)"
html-clean:
diff --git a/doc/html/images/Makefile.in b/doc/html/images/Makefile.in
index b417b93ec..2cdd8e0d6 100644
--- a/doc/html/images/Makefile.in
+++ b/doc/html/images/Makefile.in
@@ -49,14 +49,7 @@ images: visual-examples-check $(ALL_IMAGES)
pdf-images: $(PDF_IMAGES) visual-examples-pdf
visual-examples-check:
- @test -s $(VISUAL_EXAMPLES_MANIFEST) || { \
- echo "Visual examples are missing. Run 'make -C regress visual-examples' first." >&2; \
- exit 1; \
- @test -s $(VISUAL_EXAMPLES_XML_MANIFEST) || { \
- echo "Visual example XML manifest is missing. Run 'make -C regress visual-examples' first." >&2; \
- exit 1; \
+ @$(if $(shell test -s '$(VISUAL_EXAMPLES_MANIFEST)' && test -s '$(VISUAL_EXAMPLES_XML_MANIFEST)' && echo ok),true,$(error Visual examples are missing. Run 'make -C regress visual-examples' first.))
visual-examples-pdf: visual-examples-check
@mkdir -p $(PDF_IMAGES_BUILD_DIR)/$(VISUAL_EXAMPLES_DIR)
commit d9760cc174776ba7abe72572709ee84ff529239e
Date: Mon Sep 7 20:15:44 2026 -0400
GHA stop testing latest and change to pg19
- latest is now at PostgreSQL 20, which is broken against 3.7
- Instead swap out with pg19-geosmain-gdalmaster-proj98
diff --git a/.github/workflows/ci.yml b/.github/workflows/ci.yml
index 707beab9a..c9d4d16c1 100644
--- a/.github/workflows/ci.yml
+++ b/.github/workflows/ci.yml
@@ -36,9 +36,9 @@ jobs:
#- { tag: pg13-geos39-gdal31-proj71, mode: usan_gcc }
#- { tag: pg14-clang-geos39-gdal31-proj71, mode: usan_clang }
# Run tests with different dependency combinations
- - { tag: latest, mode: tests }
+ - { tag: pg19-geosmain-gdalmaster-proj98, mode: tests }
- { tag: pg18-geosmain-gdal311-proj96, mode: standard_conforming_strings_off }
- - { tag: latest, mode: garden }
+ - { tag: pg19-geosmain-gdalmaster-proj98, mode: garden }
runs-on: ubuntu-latest
steps:
commit 33bc17e7c8ef88150a624ae11c30013b9a016297
Date: Mon Sep 7 20:11:54 2026 -0400
WINNIE changes
- Update winnie default versions of libraries
- Make -j configurable, but default to 2 if not passed in
diff --git a/ci/winnie/regress_postgis.sh b/ci/winnie/regress_postgis.sh
index a51319b89..2c48f998b 100644
--- a/ci/winnie/regress_postgis.sh
+++ b/ci/winnie/regress_postgis.sh
@@ -98,7 +98,7 @@ LDFLAGS="-Wl,--enable-auto-import -L${PGPATH}/lib -L${LZ4_PATH}/lib -L${PROJECTS
#patch liblwgeom generated make to get rid of dynamic linking
#sed -i 's/LDFLAGS += -no-undefined//g' liblwgeom/Makefile
-make -j 2
+make -j $NPROC
make install
# don't run tests twice. Only run regular if extension test is not asked for
diff --git a/ci/winnie/winnie_common.sh b/ci/winnie/winnie_common.sh
index 1739cd7d7..c264be2bc 100644
--- a/ci/winnie/winnie_common.sh
+++ b/ci/winnie/winnie_common.sh
@@ -12,17 +12,17 @@ export MSYS2_ARG_CONV_EXCL=/config/tags
export XML_CATALOG_FILES="/projects/docbook/docbook-5.0.1/catalog.xml"
if [[ "${OVERRIDE}" == '' ]] ; then
- export GEOS_VER=3.13.1
- export GDAL_VER=3.9.2
- export PROJ_VER=8.2.1
+ export GEOS_VER=3.15.0
+ export GDAL_VER=3.13.1
+ export PROJ_VER=9.8.1
export SFCGAL_VER=2.3.0
- export CGAL_VER=6.0.1
+ export CGAL_VER=6.0.2
export ICON_VER=1.17
export ZLIB_VER=1.2.13
export PROTOBUF_VER=3.2.0
export PROTOBUFC_VER=1.2.1
export JSON_VER=0.16
- export PROJSO=libproj_8_2.dll
+ export PROJSO=libproj_9.dll
export LZ4_VER=1.9.3
fi;
@@ -45,6 +45,11 @@ if [[ "${ICON_VER}" == '' ]] ; then
fi;
+if [[ "${NPROC}" == '' ]] ; then
+ export NPROC=2
+fi;
echo "ICON_VER ${ICON_VER}"
if [[ "${LZ4_VER}" == '' ]] ; then
commit 748d1018fdf67b183722f801b848727faccb3fde
Date: Mon Sep 7 20:10:44 2026 -0400
PREPPING FOR 3.7.0rc2 RELEASE
- Update versions in docs
diff --git a/doc/postgis.xml b/doc/postgis.xml
index e6566362e..55c3147ea 100644
--- a/doc/postgis.xml
+++ b/doc/postgis.xml
@@ -13,10 +13,10 @@
<!-- Change these values to update the version numbers referenced within the documentation -->
<!ENTITY last_proj_release_version "9.2.1">
-<!ENTITY last_geos_release_version "3.14.0">
+<!ENTITY last_geos_release_version "3.15.0">
<!ENTITY min_geos_version "3.10.0">
<!ENTITY min_postgres_version "14">
-<!ENTITY max_postgres_version "19beta2">
+<!ENTITY max_postgres_version "19">
<!ENTITY introduction SYSTEM "introduction.xml">
<!ENTITY credits SYSTEM "credits.xml">
Summary of changes:
.github/workflows/ci.yml | 4 ++--
NEWS | 6 ++++++
ci/winnie/regress_postgis.sh | 2 +-
ci/winnie/winnie_common.sh | 15 ++++++++++-----
doc/Makefile.in | 6 +++---
doc/html/images/Makefile.in | 9 +--------
doc/postgis.xml | 4 ++--
7 files changed, 25 insertions(+), 21 deletions(-)
hooks/post-receive
