[SCM] PostGIS branch master updated. 3.7.0rc1-47-g621f8e0e2
Mon Sep 7 20:51:11 PDT 2026
the project "PostGIS".
       via  621f8e0e24602361113fe79b0833780398297aff (commit)
       via  c73080f87a4835e1a02f9e0ad5d095da0c310782 (commit)
      from  de11dcfb03729f399ffdcea1f8135dc0973c0e2b (commit)
revisions in full, below.
commit 621f8e0e24602361113fe79b0833780398297aff
Author: Regina Obe <lr at pcorp.us>
Date:   Tue Sep 8 03:50:31 2026 +0000
    Translated PostGIS Manual using Weblate (Japanese)
    Currently translated at 99.5% (6031 of 6059 strings)
    Translation: postgis/PostGIS Manual
    Translate-URL: https://weblate.osgeo.org/projects/postgis/postgis-manual/ja/
diff --git a/doc/po/ja/postgis-manual.po b/doc/po/ja/postgis-manual.po
index e07f18cad..aee632a6e 100644
--- a/doc/po/ja/postgis-manual.po
+++ b/doc/po/ja/postgis-manual.po
@@ -5,13 +5,14 @@
 # Yoichi Kayama <yoichi.kayama at gmail.com>, 2024.
 # Weblate <noreply-mt-weblate at weblate.org>, 2025.
 # Teramoto Ikuhiro <teramoto.ikuhiro576 at naro.go.jp>, 2025, 2026.
+# Regina Obe <robe at postgis.net>, 2026.
 msgid ""
 msgstr ""
 "Project-Id-Version: postgis 3.5\n"
 "Report-Msgid-Bugs-To: https://bugs.kde.org\n"
 "POT-Creation-Date: 2026-08-04 15:37+0000\n"
 "PO-Revision-Date: 2026-09-08 03:51+0000\n"
-"Last-Translator: Teramoto Ikuhiro <teramoto.ikuhiro576 at naro.go.jp>\n"
+"Last-Translator: Regina Obe <robe at postgis.net>\n"
 "Language-Team: Japanese <https://weblate.osgeo.org/projects/postgis/postgis-"
 "manual/ja/>\n"
 "Language: ja\n"
@@ -6068,7 +6069,7 @@ msgid ""
 "<varname>--without-json</varname>."
 msgstr ""
 "JSON-C。現在、ST_GeomFromGeoJson による GeoJSON の取り込みに使われます。JSON-"
-"C は link xlink:href=\"https://github.com/json-c/json-c/releases\">https://"
+"C は <link xlink:href=\"https://github.com/json-c/json-c/releases\">https://"
 "github.com/json-c/json-c/releases/</link> からダウンロードできます。"
 "デフォルトでは有効になっていますが、任意です。configure が警告を表示して"
 "ビルドを継続するだけで済まない場合には、 <varname>--without-json</varname> で"
commit c73080f87a4835e1a02f9e0ad5d095da0c310782
Author: Teramoto Ikuhiro <yellow at affrc.go.jp>
Date:   Tue Sep 8 03:04:22 2026 +0000
index 9af9403bb..e07f18cad 100644
@@ -10,7 +10,7 @@ msgstr ""
-"PO-Revision-Date: 2026-09-08 02:39+0000\n"
+"PO-Revision-Date: 2026-09-08 03:51+0000\n"
 "manual/ja/>\n"
@@ -45525,6 +45525,10 @@ msgid ""
 "link>, Use point-in-polygon predicate fast paths for point-only "
 "GeometryCollections, including ST_Disjoint (Darafei Praliaskouski)"
 msgstr ""
+"<link xlink:href=\"https://trac.osgeo.org/postgis/ticket/4749\">#4749</link>"
+", ポイントだけで構成されるジオメトリーコレクションに対するテスト関数において"
+"ポリゴン内ポイントの高速処理に変更、ST_Disjoint を含みます(Darafei "
+"Praliaskouski さん)"
 #. Tag: para
 #, no-c-format
@@ -45541,6 +45545,9 @@ msgid ""
 "link>, Allow ST_OrderingEquals joins to use hash and merge join plans "
 "(Darafei Praliaskouski)"
 msgstr ""
+"<link xlink:href=\"https://github.com/postgis/postgis/pull/875\">GH-875</"
+"link>, ST_OrderingEquals がハッシュ結合計画とマージ結合計画を使用して結合でき"
+"るようにしました。 (Darafei Praliaskouski さん)"
 #. Tag: para
 #, no-c-format
@@ -45549,6 +45556,9 @@ msgid ""
 "link>, [raster] Support curved geometry inputs in ST_AsRaster (Darafei "
 "Praliaskouski)"
 msgstr ""
+"<link xlink:href=\"https://trac.osgeo.org/postgis/ticket/1168\">#1168</link>"
+", [raster] ST_AsRaster で、曲線ジオメトリの入力に対応するように変更 (Darafei "
+"Praliaskouski)"
 #. Tag: para
 #, no-c-format
Summary of changes:
 doc/po/ja/postgis-manual.po | 17 ++++++++++++++---
 1 file changed, 14 insertions(+), 3 deletions(-)
hooks/post-receive
