[SCM] PostGIS branch master updated. 3.7.0rc1-48-g927afb703
git at osgeo.org
git at osgeo.org
Mon Sep 7 22:39:17 PDT 2026
the project "PostGIS".
via 927afb703ea802eb6fc29a33664973a5a5a98229 (commit)
from 621f8e0e24602361113fe79b0833780398297aff (commit)
revisions in full, below.
commit 927afb703ea802eb6fc29a33664973a5a5a98229
Author: Teramoto Ikuhiro <yellow at affrc.go.jp>
Date: Tue Sep 8 05:37:51 2026 +0000
Translated PostGIS Manual using Weblate (Japanese)
Currently translated at 99.6% (6040 of 6059 strings)
Translation: postgis/PostGIS Manual
Translate-URL: https://weblate.osgeo.org/projects/postgis/postgis-manual/ja/
diff --git a/doc/po/ja/postgis-manual.po b/doc/po/ja/postgis-manual.po
index aee632a6e..83ebb2e12 100644
--- a/doc/po/ja/postgis-manual.po
+++ b/doc/po/ja/postgis-manual.po
@@ -11,8 +11,8 @@ msgstr ""
"Project-Id-Version: postgis 3.5\n"
"Report-Msgid-Bugs-To: https://bugs.kde.org\n"
"POT-Creation-Date: 2026-08-04 15:37+0000\n"
-"PO-Revision-Date: 2026-09-08 03:51+0000\n"
-"Last-Translator: Regina Obe <robe at postgis.net>\n"
+"PO-Revision-Date: 2026-09-08 05:39+0000\n"
+"Last-Translator: Teramoto Ikuhiro <teramoto.ikuhiro576 at naro.go.jp>\n"
"Language-Team: Japanese <https://weblate.osgeo.org/projects/postgis/postgis-"
"manual/ja/>\n"
"Language: ja\n"
@@ -45568,6 +45568,9 @@ msgid ""
"link>, ST_AsX3D outputs NURBSCURVE as X3D NurbsCurve and linearizes other "
"curve geometries (Darafei Praliaskouski)"
msgstr ""
+"<link xlink:href=\"https://trac.osgeo.org/postgis/ticket/1416\">#1416</link>"
+", ST_AsX3D で NURBSCURVE を X3D NurbsCurve として出力するように変更、他の曲線"
+"ジオメトリーは線形化します (Darafei Praliaskouski さん)"
#. Tag: para
#, no-c-format
@@ -45576,6 +45579,9 @@ msgid ""
"link>, ST_AsX3D outputs valid coordinate nodes for 2D multi-geometries and "
"GeometryCollections (Darafei Praliaskouski)"
msgstr ""
+"<link xlink:href=\"https://trac.osgeo.org/postgis/ticket/3705\">#3705</link>"
+", ST_AsX3D で 2次元マルチ系ジオメトリーとジオメトリーコレクションについて妥当"
+"な Coordinate ノードを出力するように変更 (Darafei Praliaskouski さん)"
#. Tag: para
#, no-c-format
@@ -45584,6 +45590,9 @@ msgid ""
"484\">GT-484</link>, Use column-level SELECT privileges for metadata views "
"(Arthur Bazin)"
msgstr ""
+"<link xlink:href=\"https://gitea.osgeo.org/postgis/postgis/pulls/484\">GT-"
+"484</link>, メタデータビューでカラムレベルの SELECT 権限を使用 (Arthur Bazin "
+"さん)"
#. Tag: para
#, no-c-format
@@ -45612,11 +45621,33 @@ msgid ""
"<link xlink:href=\"https://gitea.osgeo.org/postgis/postgis/pulls/"
"584\">GT-584</link>, Numerous doc enhancements (Darafei Praliaskouski)"
msgstr ""
+"<link xlink:href=\"https://trac.osgeo.org/postgis/ticket/1408\">#1408</link>"
+", <link xlink:href=\"https://trac.osgeo.org/postgis/ticket/2386\">#2386</"
+"link>, <link xlink:href=\"https://trac.osgeo.org/postgis/ticket/2557\">"
+"#2557</link>, <link xlink:href=\"https://trac.osgeo.org/postgis/ticket/"
+"2805\">#2805</link>, <link xlink:href=\"https://trac.osgeo.org/postgis/"
+"ticket/2898\">#2898</link>, <link xlink:href=\"https://trac.osgeo.org/"
+"postgis/ticket/3743\">#3743</link>, <link xlink:href=\"https://"
+"trac.osgeo.org/postgis/ticket/4323\">#4323</link>, <link "
+"xlink:href=\"https://trac.osgeo.org/postgis/ticket/4332\">#4332</link>, "
+"<link xlink:href=\"https://trac.osgeo.org/postgis/ticket/4385\">#4385</link>"
+", <link xlink:href=\"https://trac.osgeo.org/postgis/ticket/5109\">#5109</"
+"link>, <link xlink:href=\"https://trac.osgeo.org/postgis/ticket/5532\">"
+"#5532</link>, <link xlink:href=\"https://trac.osgeo.org/postgis/ticket/"
+"5593\">#5593</link>, <link xlink:href=\"https://trac.osgeo.org/postgis/"
+"ticket/5638\">#5638</link>, <link xlink:href=\"https://trac.osgeo.org/"
+"postgis/ticket/5645\">#5645</link>, <link xlink:href=\"https://"
+"trac.osgeo.org/postgis/ticket/5950\">#5950</link>, <link "
+"xlink:href=\"https://trac.osgeo.org/postgis/ticket/6022\">#6022</link>, "
+"<link xlink:href=\"https://trac.osgeo.org/postgis/ticket/6082\">#6082</link>"
+", <link xlink:href=\"https://github.com/postgis/postgis/pull/1161\">GH-1161</"
+"link>, <link xlink:href=\"https://gitea.osgeo.org/postgis/postgis/pulls/"
+"584\">GT-584</link>, ドキュメントの多数の強化 (Darafei Praliaskouski さん)"
#. Tag: title
#, no-c-format
msgid "Bug Fixes"
-msgstr ""
+msgstr "誤り訂正"
#. Tag: para
#, no-c-format
@@ -45633,6 +45664,9 @@ msgid ""
"link>, Reject empty geometry type modifiers without an out-of-bounds read "
"(Egor Ivkov)"
msgstr ""
+"<link xlink:href=\"https://trac.osgeo.org/postgis/ticket/6118\">#6118</link>"
+", 空のジオメトリー型修飾子は範囲外を読むことなく拒絶するよう変更 (Egor Ivkov "
+"さん)"
#. Tag: para
#, no-c-format
@@ -45640,6 +45674,8 @@ msgid ""
"Fix WKB and TWKB parser resource exhaustion on malformed input (Darafei "
"Praliaskouski)"
msgstr ""
+"WKB と TWKB のパーサーが不正な入力があると資源枯渇に陥る問題を修正 (Darafei "
+"Praliaskouski さん)"
#. Tag: para
#, no-c-format
@@ -45648,6 +45684,9 @@ msgid ""
"link>, Avoid stale relation lookups in geometry_columns after topology "
"objects are dropped (Darafei Praliaskouski)"
msgstr ""
+"<link xlink:href=\"https://trac.osgeo.org/postgis/ticket/6038\">#6038</link>"
+", トポロジーオブジェクトが削除された後に geometry_columns の古いリレーション"
+"参照を避けるよう変更 (Darafei Praliaskouski さん)"
#. Tag: para
#, no-c-format
@@ -45656,6 +45695,9 @@ msgid ""
"link>, Improve error detail for repeated upgrades after an incomplete "
"deprecated-function cleanup (Darafei Praliaskouski)"
msgstr ""
+"<link xlink:href=\"https://trac.osgeo.org/postgis/ticket/5487\">#5487</link>"
+", 非推奨関数の不完全な消去の後に反復してアップグレードする時に出るエラー詳細"
+"表示の改善 (Darafei Praliaskouski さん)"
#. Tag: para
#, no-c-format
Summary of changes:
doc/po/ja/postgis-manual.po | 48 ++++++++++++++++++++++++++++++++++++++++++---
1 file changed, 45 insertions(+), 3 deletions(-)
hooks/post-receive
