[postgis] Why is there the limitation of PGLIB to get the cursor?
TONY J.Y.
tjiang at mrf.com
Wed Dec 5 12:27:17 PST 2001
I am using the PGLIB C lib to connect to PgSql to finish the query of
the GEOMETRY of a table.
At first, everything is OK. I can insert, update, delete and select of
whatever I want. But the geometry data is very small one.
So I wanted to try a bigger one. I uploaded a ESRI shape file into database
which in the attachment --- Canada.sql. Then I try the query.
res = PQexec(conn, "DECLARE mycursor BINARY CURSOR FOR select gid, name,
asbinary(the_geom) from canada");
if (!res || PQresultStatus(res) != PGRES_COMMAND_OK)
fprintf(stderr, "DECLARE CURSOR command failed\n");
PQclear(res);
exit_nicely(conn);
PQclear(res);
res = PQexec(conn, "FETCH ALL in mycursor");
if (!res || PQresultStatus(res) != PGRES_TUPLES_OK)
fprintf(stderr, "FETCH ALL command didn't return tuples
properly\n");
PQclear(res);
exit_nicely(conn);
Then I got the error when try to "FETCH ALL in mycursor".
Could you help me to figure out the problem? Thanks. I have attached
the files needed for you.
Best regards,
Tony
Tony Jiang, MSc
Research & Development Programmer/Analyst
MRF Geosystems Corp (www.mrf.com)
Suite 700, 665 8th Street SW,
Calgary, AB T2P 3K7
(403) 216-5515 ext:226
------------------------ Yahoo! Groups Sponsor ---------------------~-->
See What You've Been Missing!
Amazing Wireless Video Camera.
Click here
http://us.click.yahoo.com/75YKVC/7.PDAA/ySSFAA/PhFolB/TM
To unsubscribe from this group, send an email to:
postgis-unsubscribe at yahoogroups.com
Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20011205/a605ce7f/attachment.obj>
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20011205/a605ce7f/attachment-0001.obj>
