[postgis] postgis and shpfile library
Paul Ramsey
pramsey at refractions.net
Fri Dec 14 09:33:48 PST 2001
Mapserver can also be used to write shape files as a result of a query,
with the mapscript extension, but it is notoriously finnicky to get that
functionality to work write, so I would not recommend it unless you are
very patient.
Dave Blasby wrote:
> Jeff lounsbury wrote:
> > Use the pgsql2shp program that comes in your postgis install.
> > -Jeff
> If you're just trying to get the results of a query, you can create a
> table with the query results and then dump the table.
> CREATE TABLE blah AS (SELECT ....);
> Perhaps jeff (or someone else) could extend the pgsql2shp program to
> accept an sql query instead of a table name.
> dave
> To unsubscribe from this group, send an email to:
> postgis-unsubscribe at yahoogroups.com
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
__
| Paul Ramsey
| Refractions Research
| Email: pramsey at refractions.net
| Phone: (250) 885-0632
\_
------------------------ Yahoo! Groups Sponsor ---------------------~-->
Stop Smoking Now
Nicotrol will help
http://us.click.yahoo.com/2vN8tD/_pSDAA/ySSFAA/PhFolB/TM
