[postgis] JTS and ant.
Cameron Shorter
cameron at shorter.net
Tue Dec 18 14:05:21 PST 2001
Thanks Martin for fixing the html on the download page. (You can now
view the page in netscape).
I've downloaded the code, and started looking around. What would be
very nice is if you set up an "ant" build.xml script which can be used
to build files (like unix make).
It is useful for building releases, javadocs, etc.
More info at:
http://jakarta.apache.org/ant/
mbdavis at vividsolutions.com wrote:
> Good point, Hisaji. I've attached an example JTS program. We'll add
> examples to the src code in the next release.
> Martin Davis, Senior Technical Specialist
> Vivid Solutions Inc.
> Suite #1A-2328 Government Street Victoria, B.C. V8T 5G5
> Phone: (250) 385 6040 Fax: (250) 385 6046
> EMail: mbdavis at vividsolutions.com Web: www.vividsolutions.com
> -----Original Message-----
> From: Hisaji ONO [mailto:ono96 at fa2.so-net.ne.jp]
> Sent: Tuesday, December 18, 2001 6:03 AM
> To: mbdavis at vividsolutions.com
> Cc: postgis at yahoogroups.com
> Subject: Re: JTS 0.9 has been released
> Thank you very much for your great work, Mr. Davis.
> I've tried to create some programs by using JTS's jars.
> If possible, could you show any simple sample java programs using JTS?
> Regards.
> > I'm happy to announce that a pre-release version of the Java Topology
> Suite
> > is now available for download at
> > http://www.vividsolutions.com/jts/jtshome.htm
> > This version is functionally complete (apart from isSimple and isValid,
> > which will be release shortly).
> > The spatial predicates are robust under both Fixed and Floating precision
> > models. The spatial overlay and buffer functions are unfortunately not
> > fully robust. The overlay functions should perform similarly to most
> other
> > spatial APIs, however. The buffer function is robust and precise for many
> > inputs, but does have known failure cases.
> > We invite comments, and especially suggestions on robust, precise
> > algorithms.
> To unsubscribe from this group, send an email to:
> postgis-unsubscribe at yahoogroups.com
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
> Example1.java Type: unspecified type (application/octet-stream)
> Encoding: quoted-printable
Cameron Shorter Web Mapping Manager
Social Change Online
248 Johnson St Tel: +61 (0) 2 9692 5115
Annandale NSW 2038 Fax: +61 (0) 2 9692 5192
Sydney, Australia http://webmap.socialchange.net.au
------------------------ Yahoo! Groups Sponsor ---------------------~-->
Need new boots for winter? Looking for a perfect gift for your shoe loving friends?
Zappos.com is the perfect fit for all your shoe needs!
http://us.click.yahoo.com/ltdUpD/QrSDAA/ySSFAA/PhFolB/TM
