[postgis] About description of usage of C Clients (libpq) in PostGIS Manual
Hisaji ONO ono96 at fa2.so-net.ne.jp
Thu Jul 26 09:56:56 PDT 2001
 Thank you for your answer, Paul.
> No, no plans, but then we have no idea what support in PHP would
> constitute? I mean, if you select data out of a spatial column into PHP
> right now, it will arrive as valid well-known text. That's not bad,
> really. It's pretty easy to parse. What are you doing to do with these
> geometries once you get them into PHP? If the answer is 'draw a map
 Yes. I'd like to draw a map on IE 5.5 by converting PostGIS's geometries
(WKT or WKB) to SVG instance with Adobe SVG Plug-in, HTML and JavaScripts
via Internet or Intranet.
 I know PostGIS will support GML (output?), but I'd like to diretly convert
geometries to SVG instance.
------------------------ Yahoo! Groups Sponsor ---------------------~-->
Small business owners...
Tell us what you think!
http://us.click.yahoo.com/vO1FAB/txzCAA/ySSFAA/PhFolB/TM
To unsubscribe from this group, send an email to:
postgis-unsubscribe at yahoogroups.com
Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
