[postgis-users] geoserver beta released
Cameron Shorter cshorter at bigpond.net.au
Fri Apr 5 12:10:29 PST 2002
Hi Rob,
I've been trying to get your wfsTester to work without success.
I've been trying to build it from the ant file - no luck there.
Could you tar up a working webapp/wfsTester directory and send that to me, or
give me some hints on how to build your application using ant.
It would probably be good to put the source code into CVS.  If I ever get ant
working, I'm prepared to update it in CVS.
On Friday 29 March 2002 11:10, you wrote:
> You can get some basic NYC layers via WFS here:
>         http://beta.vfny.org/geoserver
> A couple of test requests:
>         http://beta.vfny.org/geoserver/GetCapabilities?version=0.0.14
> http://beta.vfny.org/geoserver/DescribeFeatureType?typename=boroughs
>         http://beta.vfny.org/geoserver/GetFeature?typename=boroughs
> You can also download the WFS Tester, which will let you make and store
> tests in XML format via GET or POST.  You can get that on the main
> GeoServer download page as a separate package.  It has some built in
> tests with it, although some layers on our server have been disabled due
> to a legal agreement we signed with NYC in order to acquire their data.
> Regards,
> Rob
