[postgis-users] Geotools, Geoserver and PostGIS integration
Peter Aberline
AberlineP at willis.com
Fri Apr 19 08:26:38 PDT 2002
Paul,
Thanks for your comments. It may be that a WMS based system might be the
most practical, but I was wanting the archiecture to support attribute
querying
of features on the map, rather than just a simple static display.
To the best of my knowledge, this couldn't be supported by a WMS system
unless
you got into the game of generating html image maps overlaying feature?
peter.
Paul Ramsey <pramsey at refractions.net>@postgis.refractions.net on 19/04/2002
16:07:52
Please respond to postgis-users at postgis.refractions.net
Sent by: postgis-users-admin at postgis.refractions.net
To: postgis-users at postgis.refractions.net
cc:
bcc:
Subject: Re: [postgis-users] Geotools, Geoserver and PostGIS integration
My general thought is that the best web-based OpenGIS system would be to
use WMS for 95% of the rendering, only start hitting WFS for when
feature editing becomes required. So you might want to include Mapserver
in your list of candidate technologies.
P.
Peter Aberline wrote:
> Dear Geotools, Geoserver and PostGIS mailing lists,
> I've posted this message to all three lists, appologies for cross
posting.
> I'm currently investigating various options for developing a web based
> mapping system, and geotools, geoserver and postgis seem to have
> the greatest scope for intergration. I would like to ask the groups'
> opinion of using them in an integrated way for a web based mapping
> system.
> My current thinking is around a system that stores spatial and attribute
data in
> PostgreSQL using PostGIS, having this data accessed via a Geoserver
> application server, and then using Geotools to render it in a client
> side browser applet.
> This raises some immediate questions:
> * Geotools would probably need new supporting code to handle
> the WFS request/response interaction. True?
> * Is the GML code in Geotools2 sufficiently developed to be able to
render
> data that has been sourced from a GML based data source?
> * Although WFS doesn't currently specify support for requesting raster
datasets,
> would support for this in all tiers difficult to add? This support
would
> obviously be in an out-of-standard way until WFS matured enough to
> specify an interaction.
> Obviously any new code developed to add the kind of functionality I
needed could
> be contributed back to the projects, if it was considered valuable.
> Does anyone know of any groups that have attempted to use these projects
in this way?
> I'ld be keen to hear of anyones experiences, or opinions about the likely
success
> of such a project.
> many thanks,
> Peter Aberline.
> The information in this email and in any attachments is confidential and
may be privileged. If you are not the intended recipient, please destroy
> this message, delete any copies held on your systems and notify the
sender immediately. You should not retain, copy or use this email for any
> purpose, nor disclose all or any part of its content to any other person.
> postgis-users mailing list
__
| Paul Ramsey
| Refractions Research
| Email: pramsey at refractions.net
| Phone: (250) 885-0632
\_
this message, delete any copies held on your systems and notify the sender
