[postgis-users] Geotools, Geoserver and PostGIS integration
Paul Ramsey
pramsey at refractions.net
Fri Apr 19 10:27:49 PDT 2002
The WMS spec includes support of attribute query. The only "drawback" is
that the query has to round-trip to the server to get the answer. In
light of the positive aspects of WMS over WFS (simplicity, network
bandwidth requirements, speed) it seems pretty reasonable.
Peter Aberline wrote:
> Paul,
> Thanks for your comments. It may be that a WMS based system might be the
> most practical, but I was wanting the archiecture to support attribute
> querying
> of features on the map, rather than just a simple static display.
> To the best of my knowledge, this couldn't be supported by a WMS system
> unless
> you got into the game of generating html image maps overlaying feature?
> peter.
> Paul Ramsey <pramsey at refractions.net>@postgis.refractions.net on 19/04/2002
> 16:07:52
> Please respond to postgis-users at postgis.refractions.net
> Sent by: postgis-users-admin at postgis.refractions.net
> To: postgis-users at postgis.refractions.net
> cc:
> bcc:
> Subject: Re: [postgis-users] Geotools, Geoserver and PostGIS integration
> My general thought is that the best web-based OpenGIS system would be to
> use WMS for 95% of the rendering, only start hitting WFS for when
> feature editing becomes required. So you might want to include Mapserver
> in your list of candidate technologies.
> P.
> > Dear Geotools, Geoserver and PostGIS mailing lists,
> > I've posted this message to all three lists, appologies for cross
> posting.
> > I'm currently investigating various options for developing a web based
> > mapping system, and geotools, geoserver and postgis seem to have
> > the greatest scope for intergration. I would like to ask the groups'
> > opinion of using them in an integrated way for a web based mapping
> > system.
> > My current thinking is around a system that stores spatial and attribute
> data in
> > PostgreSQL using PostGIS, having this data accessed via a Geoserver
> > application server, and then using Geotools to render it in a client
> > side browser applet.
> > This raises some immediate questions:
> > * Geotools would probably need new supporting code to handle
> > the WFS request/response interaction. True?
> > * Is the GML code in Geotools2 sufficiently developed to be able to
> render
> > data that has been sourced from a GML based data source?
> > * Although WFS doesn't currently specify support for requesting raster
> datasets,
> > would support for this in all tiers difficult to add? This support
> would
> > obviously be in an out-of-standard way until WFS matured enough to
> > specify an interaction.
> > Obviously any new code developed to add the kind of functionality I
> needed could
> > be contributed back to the projects, if it was considered valuable.
> > Does anyone know of any groups that have attempted to use these projects
> in this way?
> > I'ld be keen to hear of anyones experiences, or opinions about the likely
> success
> > of such a project.
> > many thanks,
> > Peter Aberline.
> > The information in this email and in any attachments is confidential and
> may be privileged. If you are not the intended recipient, please destroy
> > this message, delete any copies held on your systems and notify the
> sender immediately. You should not retain, copy or use this email for any
> > purpose, nor disclose all or any part of its content to any other person.
> > postgis-users mailing list
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
> __
> | Paul Ramsey
> | Refractions Research
> | Email: pramsey at refractions.net
> | Phone: (250) 885-0632
> \_
> this message, delete any copies held on your systems and notify the sender
__
| Paul Ramsey
\_
