[postgis-users] Region-style representations
Tyler Mitchell
themitchells at telus.net
Mon Apr 22 18:19:29 PDT 2002
Right on Paul, that works like a charm! Any other neat new stuff you guys
are picking at way at in CVS?
On Monday 22 April 2002 01:35 pm, you wrote:
> In the CVS version, you already can:
> select collect(the_geom) from geotable group by someattr;
> returns aggregate features (geometrycollection) grouped by an attribute.
> P.
> On Monday 22 April 2002 03:09 pm, you wrote:
> > Your definition sounds good enough to me.
> > The reason this came up is that I'm discussing using postgis with some
> > other applications which traditionally have created regions in arcinfo
> > for their analysis. Is it possible (or going to be possible) to create
> > multipolygons from polygons within postgis, via some dissolving on an
> > attribute(s) function?
> > Tyler
> > Frank Warmerdam
> > <warmerdam at pobox.com> To:
> > postgis-users at postgis.refractions.net Sent by:
> > cc:
> > postgis-users-admin at postgis.refr Fax to:
> > actions.net Subject:
> > Re: [postgis-users] Region-style representations
> > 04/22/2002 11:21 AM
> > Please respond to postgis-users
> > Tyler Mitchell wrote:
> > > Hi guys,
> > > Are there plans/possibilities of representing polygons a la ArcInfo
> > > region-style? Is this covered off in another OGC spec?
> > Tyler,
> > My understanding is that regions in arc/info are a way of making a
> > feature (with attributes) that consists of one or more simple polygons
> > that may have
> > wholes. That is region is potentially a set of disconnected areas. In
> > OGC Simple Features this would be a MultiPolygon geometry and should be
> > supported directly by PostGIS.
> > I am not absolutely certain if my OGR region handling actually treats
> > regions properly as MultiPolygons or not, but if so I would imagine they
> > could be loaded into PostGIS with ogr2ogr.
> > Best regards,
> postgis-users mailing list
