[postgis-users] Region-style representations
Paul Ramsey
pramsey at refractions.net
Mon Apr 22 18:48:17 PDT 2002
For all the news on the latest and greatest, see
http://postgis.refractions.net/CVS.txt
Updated hourly.
P.
On Monday 22 April 2002 09:19 pm, you wrote:
> Right on Paul, that works like a charm! Any other neat new stuff you guys
> are picking at way at in CVS?
> On Monday 22 April 2002 01:35 pm, you wrote:
> > In the CVS version, you already can:
> > select collect(the_geom) from geotable group by someattr;
> > returns aggregate features (geometrycollection) grouped by an attribute.
> > P.
> > On Monday 22 April 2002 03:09 pm, you wrote:
> > > Your definition sounds good enough to me.
> > > The reason this came up is that I'm discussing using postgis with some
> > > other applications which traditionally have created regions in arcinfo
> > > for their analysis. Is it possible (or going to be possible) to create
> > > multipolygons from polygons within postgis, via some dissolving on an
> > > attribute(s) function?
> > > Tyler
> > > Frank Warmerdam
> > > <warmerdam at pobox.com> To:
> > > postgis-users at postgis.refractions.net Sent by:
> > > cc:
> > > postgis-users-admin at postgis.refr Fax to:
> > > actions.net Subject:
> > > Re: [postgis-users] Region-style representations
> > > 04/22/2002 11:21 AM
> > > Please respond to postgis-users
> > > Tyler Mitchell wrote:
> > > > Hi guys,
> > > > Are there plans/possibilities of representing polygons a la ArcInfo
> > > > region-style? Is this covered off in another OGC spec?
> > > Tyler,
> > > My understanding is that regions in arc/info are a way of making a
> > > feature (with attributes) that consists of one or more simple polygons
> > > that may have
> > > wholes. That is region is potentially a set of disconnected areas. In
> > > OGC Simple Features this would be a MultiPolygon geometry and should be
> > > supported directly by PostGIS.
> > > I am not absolutely certain if my OGR region handling actually treats
> > > regions properly as MultiPolygons or not, but if so I would imagine
> > > they could be loaded into PostGIS with ogr2ogr.
> > > Best regards,
> > postgis-users mailing list
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
