[postgis] AddGeometryColumn fails -- pgsql 7.1.3 and postgis 0.6.2 okay?
Paul Ramsey
pramsey at refractions.net
Mon Jan 14 17:47:45 PST 2002
Ah.
Took me two looks to see it.
In your postgis.sql upload, note that it failed 1/2 way through, when
you try to alter the opclass. The user you are uploading postgis.sql
with does not have system privileges. Try uploading postgis.sql as the
postgres user, or give your user system privs. If the postgis.sql upload
fails you get none of the necessary function defs, and hence, no
functionality.
Paul
Tyler Mitchell wrote:
> Hi listers, I'm trying postgis out for the first time, following the docs
> closely (I think), but after all is said and done I cannot use the
> AddGeometryColumn function (see end of log below). Is it because of the
> versions I am running:
> Postgresql - 7.1.3 - installed from sources
> PostGIS - 0.6.2 - moved to pg/contrib folder and ran make; make install
> fine
> When I try to do the "SELECT AddGeometryColumn...." from the example in the
> docs it obviously can't find it.
> Yet it tells me I've got everything I need. Can you look at my stuff below
> and help me?
> Tyler
> [me at myserver postgis-0.6.2]# createlang plpgsql testgis
> createlang: 'plpgsql' is already installed in database testgis
> testgis=# \i postgis.sql
> BEGIN
> message
> plpgsql is installed
> (1 row)
> CREATE
> psql:postgis.sql:34: NOTICE: CREATE TABLE/PRIMARY KEY will create implicit
> index 'spatial_ref_sys_pkey' for table 'spatial_ref_sys'
> CREATE
> psql:postgis.sql:47: NOTICE: CREATE TABLE/PRIMARY KEY will create implicit
> index 'gc_pk' for table 'geometry_columns'
> CREATE
> CREATE
> psql:postgis.sql:213: NOTICE: ProcedureCreate: type 'box3d' is not yet
> defined
> CREATE
> CREATE
> psql:postgis.sql:223: NOTICE: ProcedureCreate: type 'spheroid' is not yet
> defined
> CREATE
> CREATE
> psql:postgis.sql:247: NOTICE: ProcedureCreate: type 'wkb' is not yet
> defined
> CREATE
> CREATE
> CREATE
> psql:postgis.sql:265: NOTICE: ProcedureCreate: type 'chip' is not yet
> defined
> CREATE
> CREATE
> CREATE
> psql:postgis.sql:286: NOTICE: ProcedureCreate: type 'geometry' is not yet
> defined
> CREATE
> CREATE
> psql:postgis.sql:323: NOTICE: ProcedureCreate: return type 'geometry' is
> only a shell
> CREATE
> CREATE
> psql:postgis.sql:753: ERROR: pg_opclass: Permission denied.
> psql:postgis.sql:761: NOTICE: current transaction is aborted, queries
> ignored until end of transaction block
> *ABORT STATE*
> psql:postgis.sql:768: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:775: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:782: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:789: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:796: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:803: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:810: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:817: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:819: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:827: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:833: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:839: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:845: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:851: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:857: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:863: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:866: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:867: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> COMMIT
> testgis=# drop table gtest;
> DROP
> testgis=# create table gtest (ID int4, NAME varchar(20) );
> CREATE
> testgis=# SELECT AddGeometryColumn('testgis','gtest','geom',
> -1,'LINESTRING',2);
> ERROR: Function 'addgeometrycolumn(unknown, unknown, unknown, int4,
> unknown, int4)' does not exist
> Unable to identify a function that satisfies the given argument
> types
> You may need to add explicit typecasts
> testgis=#
> To unsubscribe from this group, send an email to:
> postgis-unsubscribe at yahoogroups.com
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
__
| Paul Ramsey
| Refractions Research
| Email: pramsey at refractions.net
| Phone: (250) 885-0632
\_
------------------------ Yahoo! Groups Sponsor ---------------------~-->
Sponsored by VeriSign - The Value of Trust
When building an e-commerce site, you want to start with a
secure foundation. Learn how with VeriSign's FREE Guide.
http://us.click.yahoo.com/oCuuSA/XdiDAA/yigFAA/PhFolB/TM
