[postgis] Viewing mapserver itasca demo layer using postgis
Paul Ramsey
pramsey at refractions.net
Mon Jan 21 12:14:55 PST 2002
Change your STATUS to DEFAULT and see if that helps.
P.
Tyler Mitchell wrote:
> Okay, I've used shp2pgsql to put the ctybdpy2.shp into a table with the
> same name. But I don't get any information on my map. I've compiled
> postgresql and postgis from source and successfully compiled mapserver to
> support it.
> Here are my various settings - can you spy a problem?
> BTW - the only thing I have in my error_log is: gd-png warning: alpha
> channel not supported which I think is some other problem (I think it's
> from my conversion of gif->png I did earlier).
> Here's the layer in the map file (it's the first layer):
> LAYER
> CONNECTIONTYPE postgis
> NAME "ctybdpy2"
> CONNECTION "dbname=testgis"
> DATA "the_geom from ctybdpy2"
> TYPE POLYGON
> STATUS ON
> CLASS
> EXPRESSION ([cty_name] = 'Itasca')
> OUTLINECOLOR 128 128 128
> COLOR 225 225 185
> END
> CLASS # every other county in the state
> EXPRESSION /./
> COLOR 255 255 255
> END
> METADATA
> WMS_TITLE "County Boundary"
> WMS_ABSTRACT "Itasca County boundary shapefile. See
> http://deli.dnr.state.mn
> WMS_SRS "EPSG:26915"
> END
> END
> Here are the various listings from pgsql. Is it a permissions problem? I
> put in permissions for nobody, is that necessary?
> testgis=# \dp
> Access permissions for database "testgis"
> Relation | Access permissions
> ctybdpy2 | {"=r","mitchtj=r","root=arwR","nobody=r"}
> geometry_columns |
> spatial_ref_sys |
> (7 rows)
> testgis=# \d ctybdpy2
> Table "ctybdpy2"
> Attribute | Type | Modifier
> gid | integer |
> area | double precision |
> perimeter | double precision |
> cty_name | character varying |
> coun | integer |
> cty_abbr | character varying |
> island | character varying |
> cty_fips | integer |
> recno | integer |
> the_geom | geometry |
> Constraints: (srid(the_geom) = -1)
> ((geometrytype(the_geom) = 'MULTIPOLYGON'::text) OR (the_geom
> ISNULL))
> To unsubscribe from this group, send an email to:
> postgis-unsubscribe at yahoogroups.com
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
__
| Paul Ramsey
| Refractions Research
| Email: pramsey at refractions.net
| Phone: (250) 885-0632
\_
------------------------ Yahoo! Groups Sponsor ---------------------~-->
Sponsored by VeriSign - The Value of Trust
Do you need to encrypt all your online transactions? Find
the perfect solution in this FREE Guide from VeriSign.
http://us.click.yahoo.com/vCuuSA/UdiDAA/yigFAA/PhFolB/TM
