[postgis] Viewing mapserver itasca demo layer using postgis
Tyler Mitchell
tmitchell at lignum.com
Mon Jan 21 13:25:45 PST 2002
No change. I get all the other shapefile layers showing just fine, but
none from this file.
All I've done was run the shp2pgsql, load the sql that it generated, then
"grant select on ctybdpy to public".
Then made my changes in the map file according to the online postgis docs.
Is there any projection stuff I need to do?
Has anyone else went through this process, or have a database table that I
could load to try this with. I'm not convinced I loaded postgis right -
but I did it by the book and didn't get any errors. Anything I should
check?
Paul Ramsey
<pramsey at refrac To: postgis at yahoogroups.com
tions.net> cc:
Fax to:
01/21/2002 Subject: Re: [postgis] Viewing mapserver itasca demo layer using
12:14 PM postgis
Please respond
to postgis
Change your STATUS to DEFAULT and see if that helps.
P.
Tyler Mitchell wrote:
> Okay, I've used shp2pgsql to put the ctybdpy2.shp into a table with the
> same name. But I don't get any information on my map. I've compiled
> postgresql and postgis from source and successfully compiled mapserver to
> support it.
> Here are my various settings - can you spy a problem?
> BTW - the only thing I have in my error_log is: gd-png warning: alpha
> channel not supported which I think is some other problem (I think it's
> from my conversion of gif->png I did earlier).
> Here's the layer in the map file (it's the first layer):
> LAYER
> CONNECTIONTYPE postgis
> NAME "ctybdpy2"
> CONNECTION "dbname=testgis"
> DATA "the_geom from ctybdpy2"
> TYPE POLYGON
> STATUS ON
> CLASS
> EXPRESSION ([cty_name] = 'Itasca')
> OUTLINECOLOR 128 128 128
> COLOR 225 225 185
> END
> CLASS # every other county in the state
> EXPRESSION /./
> COLOR 255 255 255
> END
> METADATA
> WMS_TITLE "County Boundary"
> WMS_ABSTRACT "Itasca County boundary shapefile. See
> http://deli.dnr.state.mn
> WMS_SRS "EPSG:26915"
> END
> END
> Here are the various listings from pgsql. Is it a permissions problem?
I
> put in permissions for nobody, is that necessary?
> testgis=# \dp
> Access permissions for database "testgis"
> Relation | Access permissions
> ctybdpy2 | {"=r","mitchtj=r","root=arwR","nobody=r"}
> geometry_columns |
> spatial_ref_sys |
> (7 rows)
> testgis=# \d ctybdpy2
> Table "ctybdpy2"
> Attribute | Type | Modifier
> gid | integer |
> area | double precision |
> perimeter | double precision |
> cty_name | character varying |
> coun | integer |
> cty_abbr | character varying |
> island | character varying |
> cty_fips | integer |
> recno | integer |
> the_geom | geometry |
> Constraints: (srid(the_geom) = -1)
> ((geometrytype(the_geom) = 'MULTIPOLYGON'::text) OR
(the_geom
> ISNULL))
> To unsubscribe from this group, send an email to:
> postgis-unsubscribe at yahoogroups.com
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
__
| Paul Ramsey
| Refractions Research
| Email: pramsey at refractions.net
| Phone: (250) 885-0632
\_
------------------------ Yahoo! Groups Sponsor ---------------------~-->
Sponsored by VeriSign - The Value of Trust
Do you need to encrypt all your online transactions? Find
the perfect solution in this FREE Guide from VeriSign.
http://us.click.yahoo.com/vCuuSA/UdiDAA/yigFAA/PhFolB/TM
