[postgis-users] using avpgcon
Paul Ramsey
pramsey at refractions.net
Fri Jul 26 14:19:12 PDT 2002
pgsql2shp is probably (correctly) ascertaining that the datatype of
'thistime' is date. It is then trying to map into a DBF 'DATE' field,
which consists of 8 characters in the traditional YYYYMMDD format. The
trouble is that the string representation it is getting from pgsql does
not fit into that field format. I am not sure of an elegant fix...
P.
"Robert W. Burgholzer" wrote:
> Armin/list,
> This may be a bug in pgsql2shp.exe, of course I will try to take some time to
> look at it myself, but i thought I would report it to you first. When
> retrieving a column of type "timestamp" from a postgis database using the
> avpgcon interface everything is truncated save the first two fields.
> Example:
> field "thistime" on server: 1985-07-31 04:05:16-04
> field "thistime" in ArcView: 1985-07-
> Now, I note that the size of the field "thistime" is 8 characters in ArcView,
> which suggest that either this is a limit on the text fields, or pgsql2shp.exe
> is truncating.
> Any thoughts?
> postgis-users mailing list
