[postgis-users] Why the creation of an index GIST is much faster thanthe creation of an index RTREE
david.garnier at etudier-online.com david.garnier at etudier-online.com
Tue Jun 11 03:30:19 PDT 2002
> It seems to me that not only do GIST and R-tree differ in approach
> (lossiness, the stats they gather)
>  but that GIST is simply more fully implemented in postgres.
> Hope this is of use,
> Rob
I had at look the definition of R-tree and GiST, and basically a GiST is a
generic tree structure that can be used to implement, guess what, R-trees and B-
trees. So when you use a GiST index in Postgis, you basically use an R-tree. I
think that the difference in speed comes from the fact that the new
implementation of the R-tree using the GiST is better than the older, native
one.
Best regards,
David Garnier
