[postgis-users] contrib-intarray for GIST in PostGIS-0.7.1
Tom Melhuish tmelhuish at webinsights.org
Tue Jun 11 03:58:05 PDT 2002
I have installed Postgresql-7.2.1 and PostGIS-0.7.1. I’m trying to install contrib-intarray to support GIST, but I can only find a version that is compatible to Postgresql-7.1.x. I seen that they’re patches for contrib-intarray for Postgres-7.2.1 on the GIST for postgresql website <http://www.sai.msu.su/~megera/postgres/gist/> but no version of contrib-intarray that is compatible to Postgresql-7.2.1. My questions are:
1)What needs to be installed to support GIST in Postgis-0.7.1 or does Postgis-0.7.1 or Postgresql-7.2.1 already have the GIST software included with the build? I installed contrib-intarray separately to get PostGIS-0.6.1 working with GIST.
I tried to install contrib-intarray for Postgres-0.7.1.X on my Postgresql-7.2.1 install and get the following error messages:
		-int.c: In function 'g_int_consistent' :
		-int.c: structure has no member named 'pred'
2)What is the instruction to install the Patches noted in the GIST for postgresql website <http://www.sai.msu.su/~megera/postgres/gist/> . I assume I copy these into the directory where I did the gmake for Postgresql and run them as root.
Tom Melhuish
Consultant
WebInsights
703.255.5127
Email: tmelhuish at webinsights.org
