[postgis-users] contrib-intarray for GIST in PostGIS-0.7.1
Paul Ramsey pramsey at refractions.net
Tue Jun 11 07:57:11 PDT 2002
You are quite timely :)
intarray uses GiST, GiST API was changed from 7.1 to 7.2, so using
intarray from 7.1 under 7.2 will fail.
However.
Theodor submitted a patched intarray to the maintainers only last week,
and it was committed to CVS only a couple days ago. Check out the CVS
version of PostgreSQL and use that intarray under your 7.2 installation
and everything should be fine.
You do not need to patch GiST at all, the 7.2.1 GiST shipping in
postgresql is just fine. All you need is the version of intarray which
has been reworked to the new GiST API, and as I said, that is now in the
CVS version of postgresql.
Tom Melhuish wrote:
> I have installed Postgresql-7.2.1 and PostGIS-0.7.1. I’m trying to install contrib-intarray to support GIST, but I can only find a version that is compatible to Postgresql-7.1.x. I seen that they’re patches for contrib-intarray for Postgres-7.2.1 on the GIST for postgresql website <http://www.sai.msu.su/~megera/postgres/gist/> but no version of contrib-intarray that is compatible to Postgresql-7.2.1. My questions are:
> 1)What needs to be installed to support GIST in Postgis-0.7.1 or does Postgis-0.7.1 or Postgresql-7.2.1 already have the GIST software included with the build? I installed contrib-intarray separately to get PostGIS-0.6.1 working with GIST.
> I tried to install contrib-intarray for Postgres-0.7.1.X on my Postgresql-7.2.1 install and get the following error messages:
>                 -int.c: In function 'g_int_consistent' :
>                 -int.c: structure has no member named 'pred'
> 2)What is the instruction to install the Patches noted in the GIST for postgresql website <http://www.sai.msu.su/~megera/postgres/gist/> . I assume I copy these into the directory where I did the gmake for Postgresql and run them as root.
> Tom Melhuish
> Consultant
> WebInsights
> 703.255.5127
> Email: tmelhuish at webinsights.org
> postgis-users mailing list
