[postgis-users] Fun with multikey GiST
Andy Turk
andy at streetlight.com
Fri Jun 21 17:06:28 PDT 2002
On Friday 21 June 2002 03:58 pm, you wrote:
> I am disappointed that the multikey GiST was not more effective. I would
> have hoped it would return results just as fast as pure geometric
> queries. One possibility for multidimensional searching is generalizing
> the RTree index we are using to operate in 3-space. That way one could
> index features pseudo geometrically, with the Z value standing in for
> some other parameter. A ways away though...
I suspect that the distribution of keys is more of an issue than the outright
performance of multikey GiST.
The RTree over GiST index is pretty efficient over my data because there's
relatively little overlap between the geometries and the "sizes" aren't
skewed. In essence, while my data is made up of line segments, the bounding
area of each segment is roughly the same size and only overlaps its immediate
neighbors.
The string hashes are more random and the min-max bounds of a collection of
hash values almost certainly overlap in ways that are inconvenient for the
index.
When the index is being created, the algorithm (I think) looks at the leaf
nodes thus far and then chooses one of the dimensions to make the split. The
dimension with the greatest separation is used. I'm reaching here, but I
think that the geometry dimension(s) separate nicely, while the hash
dimension is a mess. This will probably force the index into less than
optimal behavior.
One tool that would be really useful is to have an overall measure of the
overlap within the index node hierarchy. If everything partitions out nicely
with little overlap, then it'll be very efficient because most of the
subnodes will be eliminated from the search. If there's a lot of overlap,
then more subnodes will have to be searched and performance will suffer.
Anyway, I'll have to figure out how to speed this query up because I need to
increase the data in the table by another order of magnitude for our software
to be functional (woo hoo!).
