[postgis-users] Newbie: Windows Install Help
Hankley, Chip Chip.Hankley at GASAI.Com
Mon Jun 24 11:23:09 PDT 2002
Norman...
I've retried this using several download options w/ cygwin setup. I first
just downloaded the binary, then the source. Either way, I'm still getting
the same error:
  pg_passwd.o(.text+0x763):pg_passwd.c: undefined reference to `crypt'
  collect2: ld returned 1 exit status
  make[3]: *** [pg_passwd] Error 1
  make[2]: *** [all] Error 2
  make[1]: *** [all] Error 2
  make: *** [all] Error 2
... I logged the make session, and this appears to be the offending line:
  make[3]: Entering directory
`/usr/src/postgresql-7.2.1-2/src/bin/pg_passwd'
  gcc -O2 -Wall -Wmissing-prototypes -Wmissing-declarations -L/usr/local/lib
-g  pg_passwd.o -lz -lreadline
    -lcygipc -o pg_passwd
If I look in the configure log file, I also see the following two lines:
  checking for library containing crypt... (cached) no
...and
  checking for crypt.h... (cached) no
So...I'm totally confused... do I have to re-configure cygipc to make it
recognize the new library? Do I need to run "make" on crypt before I run the
postgreSQL configure? The name of the source directory for crypt is
crypt-1.0, not just crypt... could this be the problem?
TIA
Chip
-----Original Message-----
Sent: Friday, June 21, 2002 4:10 PM
To: postgis-users at postgis.refractions.net
Cc: jason at tishler.net
Subject: RE: [postgis-users] Newbie: Windows Install Help
rerun the cygwin setup program and make sure you have 'crypt'
package selected for download under the 'Libs' category and
try building again
Norman
>From: postgis-users-admin at postgis.refractions.net
>[mailto:postgis-users-admin at postgis.refractions.net]On Behalf Of
>Hankley, Chip
>Sent: Friday, June 21, 2002 4:46 PM
>To: 'Tyler Mitchell'; postgis-users at postgis.refractions.net
>Thanks Tyler... that got me a LITTLE farther! Still problems though.
>I followed Norman Vine's instructions from last year - see
>http://postgis.refractions.net/pipermail/postgis-users/2001-Jun
>e/000025.html
>The last few lines of the output after I make (this is the make for
>PostgreSQL) show errors:
>/usr/lib/gcc-lib/i686-pc-cygwin/2.95.3-5/../../../../i686-pc-cy
>gwin/bin/ld:
>cannot find -lcrypt
>dllwrap: gcc exited with status 1
>make[1]: *** [array_iterator.dll] Error 1
>rm array_iterator.o
>make[1]: Leaving directory `/usr/src/postgresql-7.2.1-2/contrib/array'
>The only error that I see is the "cannot find -lcrypt. Sure
>enuf, there's
>not a file or directory by that name in the
>i686-pc-cygwin/bin/ - is that
>what this means? Where can I get it? Are the instructions
>Norman provided
>still valid?
>TIA!
>Chip Hankley
>_______________________________________________
>postgis-users mailing list
>http://postgis.refractions.net/mailman/listinfo/postgis-users
