It replaces the Makefile in the 'loader' subdirectory. Chris Hodgson "Hankley, Chip" wrote: > Thanks Norman... > > What do I do with the attached file? Simply replacing the original makefile > with that doesn't work. I assume that I should be adding those lines in to > the original or something. > > Thanks! > > Chip >
