[postgis-users] Using OGR to read VPF/ODGI vectors?
John Reid jgreid at uow.edu.au
Thu May 2 22:29:04 PDT 2002
Hopefully this is a really stupid question.  I can't seem to locate any
layers using ogrinfo:
$ ogrinfo gltp:/vrf/home/<snip>/Global_Map/Area
ERROR 4: OGDI Driver doesn't support update.
Had to open data source read-only.
INFO: Open of
`gltp:/vrf/home/gdata/auslig/Global1M/Global_Map_Data_Australia_1M_2001/Vector/VPF/Australia/Global_Map/Area'
using driver `OGDI' successful.
http://gdal.velocet.ca/projects/opengis/ogrhtml/ogr_utilities and
drv_ogdi.html indicate that this should "report a list of available
layers (and their layerwide geometry type)".
Attached is the output from:
$ ogdi_info -u gltp:/vrf/home/<snip>/Global_Map/Area
I'm just learning about the VPF format, however from this output I
gather that I should have the following coverages:
Coverage_name: tileref
Description: Tile Reference
Level: 3
Coverage_name: bnd
Description: Boundaries
Level: 3
Coverage_name: hydro
Description: Hydrography
Level: 3
Coverage_name: pop
Description: Population
Level: 3
Coverage_name: trans
Description: Transportation
Level: 3
Any ideas/recommendations?  FWIW, ArcGIS 8.1 only seemed to recognize a
"tileref" layer, not the others....
cheers,
John
john reid                                     e-mail jgreid at uow.edu.au
uproot your questions from their ground and the dangling roots will be
seen.  more questions!
                                                       -mentat zensufi
apply standard disclaimers as desired...
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20020503/cde99c4a/attachment.txt>
