[postgis-users] itemnquery limitation
Paul Ramsey
pramsey at refractions.net
Wed Aug 6 09:39:31 PDT 2003
Have you confirmed that this is an issue specific to PostGIS, or does
it happen with Shapefiles also?
P.
On Wednesday, August 6, 2003, at 09:34 AM, Tom Melhuish wrote:
> I’m performing an itemnquery and if I have 21 items in the list mapserv
> works fine. If I have 22 in the list mapserv hangs and I end up with a
> “premature end of script header” with no other error messages. Below
> is the
> declare statement out of mapserv with 22 items listed, that doesn’t
> work and
> 21 items that does work. I have about 50 nodeid and switched nodeid
> around
> to confirm that I didn’t have a bad one in the list. A set of 21 works
> fine
> and 22 or more hangs running mapserv. If I run this DECLARE statement
> in
> postgresql it excecute "OK". If I run just the SELECT statement out of
> this
> is runs fine and gives me the results I expect.
> Is their a limit in the C code that I can change to get around this in
> mapserv?
> 22 Items - fails
> DECLARE mycursor BINARY CURSOR FOR SELECT
> nodeid::text,asbinary(force_collection(force_2d(the_geom)),'NDR'),OID::
> text
> from nodescomb_2003 WHERE (nodeid in
> ('413.0','430.0','431.0','432.0','433.0','434.0','436.1','450.0','451.0
> ','45
> 2.0',
> '453.0','454.0','455.0','456.0','457.1','457.2','457.3','457.4','458.1'
> ,'458
> .2','459.0','528.0')) and (the_geom && setSRID( 'BOX3D(2001272.875
> 643833.625,2099924.5
> 696954.5)'::BOX3D,find_srid('','nodescomb_2003','the_geom') ))
> 21 Items – works fine
> text
> ','45
> 2.0',
> ,'458
> .2','459.0')) and (the_geom && setSRID( 'BOX3D(2001272.875
> I’m running Mapserver 3.6.6, Postgres 7.3.2 & Postgis 0.7.4.
> I really have the database set up to execute the following command
> that will
> extract all of the nodeid (about 50) that are associated to a Base
> type.
> After many days trying to troubleshoot the problem I rewrote the code
> to run
> on individual items (nodeid). When I run this command I get the same
> results
> as the delare statement with 22 or more items.
> text
> from nodescomb_2003 WHERE (Base10='428') and (the_geom && setSRID(
> 'BOX3D(2001272.875 643833.625,2099924.5
> Please let me know if you need more information to debug mu problem.
> Tom Melhuish
> postgis-users mailing list
Paul Ramsey
Refractions Research
Email: pramsey at refractions.net
Phone: (250) 885-0632
