[postgis-users] itemnquery limitation
Tom Melhuish
tmelhuish at webinsightsinc.com
Fri Aug 8 04:40:54 PDT 2003
Dave,
I downloaded CVS 4.0 nightly build and ran it with the same exact results. A
set of 21 items works but 22 doens't. The dates on the Mappostgis.c are:
Mappostgis.c - version of June 12/2003
I have configured my application using shapefiles and it works fine with
mapserv. Below is the select statement that doesn't work in mapserv but runs
fine in psql:
SELECT
nodeid::text,asbinary(force_collection(force_2d(the_geom)),'NDR'),OID::text
from nodescomb_2003 WHERE (nodeid in
('413.0','430.0','431.0','432.0','433.0','434.0','436.1','450.0','451.0','45
2.0',
'453.0','454.0','455.0','456.0','457.1','457.2','457.3','457.4','458.1','458
.2','459.0','528.0')) and (the_geom && setSRID( 'BOX3D(2001272.875
643833.625,2156198.25
771771.5625)'::BOX3D,find_srid('','nodescomb_2003','the_geom') ))
tom
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net]On Behalf Of Paul
Ramsey
Sent: Thursday, August 07, 2003 5:20 PM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] itemnquery limitation
You need to pull the 3.6 branch... you might have to ask a developer
what the correct tag is...
P.
Tom Melhuish wrote:
> Dave,
> The cvs version now is 4.0. How can I get a copy of the latest cvs 3.6.6
> version? I downloaded CVS 4.0 mappostgis.c and tried to compile with 3.6.6
> but it failed.
> tom
> [mailto:postgis-users-bounces at postgis.refractions.net]On Behalf Of David
> Blasby
> Sent: Wednesday, August 06, 2003 4:07 PM
> Tom Melhuish wrote:
>>I'm using 3.6.6 and the error message date is:
>> Mappostgis.c - version of May 15/2003.
> Try a more recent version from the mapserver CVS - the latest 3.6.6 is
> June 12/2003.
> dave
> postgis-users mailing list
__
| Paul Ramsey
| Refractions Research
| Email: pramsey at refractions.net
| Phone: (250) 885-0632
\_
