[postgis-users] itemnquery limitation
Zamil Murji
Zamil.Murji at divestco.com
Fri Aug 8 10:00:02 PDT 2003
Funny thing...my experience with the current data is the exact opposite. I have 1.6 million entries in the database. The quad-tree index on the shapefile actually slows it down, even after i played with the depth. The fastest i got to display an image was 9 seconds with a index of depth 1. Without the index I display at 8.5 seconds. With the postgis layer I display images at 3 - 3.5 sec. BIG difference heh?
Some more info. My query url is: http://10.0.50.30/cgi-bin/mapserv?mode=nquery&map=/mapfiles/idc-query.map&imgext=-98.86893+27.99863+-98.76535+28.10418&mapsize=524+534&imgbox=203+244+438+408
The records come back real fast. It hangs for some reason at the end. I did some playing around and if the box has less then 35 it comes back just fine. If more then i get an Error:java.io.IOException: Premature EOF when reading the url in JAVA, and through IE it just sits and rotates. Seems like it is always the last record that it has trouble closing or something.
How can I display the select statement in my browser?
Help..
Zamil
-----Original Message-----
From: chodgson at refractions.net [mailto:chodgson at refractions.net]
Sent: Friday, August 08, 2003 10:44 AM
To: PostGIS Users Discussion
Subject: RE: [postgis-users] itemnquery limitation
Quoting Zamil Murji <Zamil.Murji at divestco.com>:
> Could be related to the the bug tom is experiencing. For the time being, I
> pulled a shapefile from my postgis layer and am querying that. Speeds are
> horrendous for displaying it though, so I'm stuck wiht two sources of data (a
> postgis for display and a shapefile for querying).
It shouldn't be that slow to render the shapefile... unless it is huge? You do
have a quad-tree index on it, right? My experience has been that shapefiles are
faster than postgis (but obviously less flexible).
(http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?ShpTree)
Chris
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
