[postgis-users] itemnquery limitation
Zamil Murji Zamil.Murji at divestco.com
Mon Aug 11 13:50:05 PDT 2003
I am in the process of trying this out. FYI, I am not doing an itemnquery, I am doing an NQUERY.
Sorry for the confusion.
Will debug msg still come through?
Zamil
-----Original Message-----
From: David Blasby [mailto:dblasby at refractions.net]
Sent: Monday, August 11, 2003 2:44 PM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] itemnquery limitation
Zamil Murji wrote:
>  Can you think of any reason why this may be?
Unfortunately, no.  It seems to be working fine on my machine.  Perhaps
its because I'm directly running the cgi mapserv instead of hitting it
with an httpd.
> Could you try installing the new mappostgis.c and running your query?
> It should give some output (probably in your httpd's error_log) like this:
> msPOSTGISLayerGetShape called for record = 3532689
> msPOSTGISLayerGetShape sql=DECLARE mycursor BINARY CURSOR FOR SELECT
> asbinary(force_collection(force_2d(the_geom)),'NDR') from nodescomb_2003
> WHERE OID = 3532689
Did you find this?
dave
ps. I cannot access your url, but thats ok.
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
