[postgis-users] itemnquery limitation
David Blasby
dblasby at refractions.net
Wed Aug 13 12:28:14 PDT 2003
Tom Melhuish wrote:
> Can you provide me some instruction on turning on the debugger you are
> referring to. I have no problem running the debugger.
1. recompile mapserver with debug (either ./configure with
--enable-debug or change you Makefile so CFLAGS has "-g" in it.
2. run your program like this:
a. from your command line: gdb <mapserv executable>
b. from inside gdb: set args <your big "QUERY_STRING=..." argument>
c. run the program using gdb's "r" command. (type in "r" then enter)
d. wait a little while until its "stuck"
e. hit control-C
f. use gdb's "where" command.
g. continue the program with the "c" command
h. wait a little while
i. hit control-C
The "where" command will give you the current call stack in the program
and, hence, where's it stuck.
dave
