[postgis-users] error running postgis.sql
Chris Faulkner
chrisf at oramap.com
Wed Aug 20 05:40:17 PDT 2003
HI
I am on RedHat 9.0. I just replaced all occurences of $libdir with
/usr/local/pgsql/lib and it all went it OK, seemingly. I was (and still am)
a little worried that the failure of $libdir might be indicative of a deeper
problem and editing postgis.sql might not be getting to the cause of it.
If you have to edit $libdir, I would have expected the install guide to say
something. I am hoping that the make process that creates postgis.sql didn't
evaluate $libdir.
Any other feedback from anyone ?
Chris
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net]On Behalf Of Obe,
Regina DND\MIS
Sent: 20 August 2003 13:25
To: 'PostGIS Users Discussion'
Subject: RE: [postgis-users] error running postgis.sql
On cygwin - I've never been successful in getting that to work so I just
change $libdir in the postgis.sql with the path to the lib folder e.g.
/lib
Sent: Wednesday, August 20, 2003 8:14 AM
To: PostGIS Users Discussion
Subject: [postgis-users] error running postgis.sql
Hello
I have successfully built, installed postgres 7.3.2 and postgis 0.7.5. I am
using the template1 database, createlang worked OK.
When I run postgis.sql, I get this
ERROR - stat failed on file '$libdir/libpostgis... '
when it is running the first 2d histogram CREATE FUNCTION command in
postgis.sql.
The shared library it wants is installed, within a location on the
LD_LIBRARY_PATH when I started postmaster and psql.
Is $libdir a built-in variable. How and when is it set ?
Thanks
Chris Faulkner
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
