[postgis-users] server crash
sdjiangwei
sdjiangwei at sina.com
Thu Aug 21 22:07:12 PDT 2003
gis=# select transfrom('SRID=2001,POINT(100 100)'::geometry,2001);
server closed the connection unexpectedly
This probably means the server terminated abnormally
before or while processing the request.
The connection to the server was lost. Attempting reset: LOG: server process (pid 22849) was terminated by signal 11
LOG: terminating any other active server processes
LOG: all server processes terminated; reinitializing shared memory and semaphores
FATAL: The database system is starting up
Failed.
!# LOG: database system was interrupted at 2003-08-22 12:00:37 CST
LOG: checkpoint record is at 0/11CA5E94
LOG: redo record is at 0/11CA5E94; undo record is at 0/0; shutdown FALSE
LOG: next transaction id: 1444566; next oid: 382105
LOG: database system was not properly shut down; automatic recovery in progress
LOG: redo starts at 0/11CA5ED4
LOG: ReadRecord: record with zero length at 0/11F0E7B0
LOG: redo done at 0/11F0E78C
[postgres at database contrib]$ ldd /usr/local/pgsql/lib/libpostgis.so
libstdc++.so.5 => /usr/lib/libstdc++.so.5 (0x40030000)
libgeos.so.1 => /usr/local/lib/libgeos.so.1 (0x400e3000)
libproj.so.0 => /usr/local/lib/libproj.so.0 (0x401a3000)
libc.so.6 => /lib/tls/libc.so.6 (0x42000000)
libm.so.6 => /lib/tls/libm.so.6 (0x401d6000)
libgcc_s.so.1 => /lib/libgcc_s.so.1 (0x401f8000)
/lib/ld-linux.so.2 => /lib/ld-linux.so.2 (0x80000000)
