[postgis-users] unable to make postgresql 7.2.3: please help
Norman Vine nhv at cape.com
Tue Aug 26 19:05:58 PDT 2003
Venu Kanaparthy  writes:
  Thanks, Norman,  'make clean'. did the job and i was able to compile
postgis with
  postgresql. There is a small problem associated when i ran the following
command.
  Any help is appreciated.
  cd /usr/src/postgresql-7.3.4-2/contrib/postgis-0.7.5
  $ psql  -d myGISdb  -f postgis.sql
  BEGIN
          message
   PL/PgSQL is installed.
  (1 row)
  NOTICE:  ProcedureCreate: type histogram2d is not yet defined
  psql:postgis.sql:18: NOTICE:  ProcedureCreate: type histogram2d is not yet
defin
  ed
  ERROR:  stat failed on file '$libdir/postgis.dll': No such file or
directory
  psql:postgis.sql:18: ERROR:  stat failed on file '$libdir/postgis.dll': No
such
  file or directory
  assuming you have everything installed in the 'normal' place
  copy postgis.dll to  $CYGWIN_ROOT/lib/postgresql
  You will know if you have things installed in their cannonical
  place if you see many other postgresql dlls there
  Norman
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20030826/3e2ea68b/attachment.html>
