[postgis-users] shp2psql problem
javier garcia - CEBAS rn001 at cebas.csic.es
Wed Aug 27 14:48:20 PDT 2003
Hi all;
I've seen that other problems related to shp2psql have benn posted previously
to the list; but it didn't help me.
I've an absolute beginner with postgis, and I've just installed it.
I've got a shapefile (ESRI Arcmap8.1) that would like to import into
Postgres. So, when I saw this program I was absolutely happy.
I've run it and it appears to run correctly as no error message appears, but,
eventually, when I look up the new table in the database it doesn't appears.
So, it is simply not created.
The shapefile is rather big, (about 5000 polygons).
What could be the source of the problem?
Best regards
Javier
