[postgis-users] on-the-fly MMS reprojection with PostGIS?
Gregory S. Williamson
gsw at globexplorer.com
Wed Aug 27 17:27:54 PDT 2003
Added a projection layer for the postgres data and it works like a charm. Sorry to have taken up bandwidth ...
Greg Williamson
DBA GlobeXplorer
-----Original Message-----
Sent: Wednesday, August 27, 2003 3:41 PM
To: PostGIS Users Discussion
Subject: [postgis-users] on-the-fly MMS reprojection with PostGIS?
greetings - I am trying to use Minn Map Server to specify an output file in one projection, and add PostGIS layers that may exist in another (mostly EPSG id 4326). I'd like to simply tweek the EXTENT and the PROJECTION tags of the overall map to change the outputs.
A simple mapfile (derived from the itasca demo) I am trying is below; but unfortunately this doesn't seem to work properly...
What's the proper way to change output projection, if the PostGIS tables are in various projections, and properly loaded into the geometry_columns table?
thanks in advance!
Chris Nicholas
GlobeXplorer
NAME DEMO
STATUS ON
SIZE 600 600
EXTENT 388107.634400379 5203120.88405952 500896.339019834 5310243.30613897
UNITS METERS
IMAGECOLOR 255 255 255
IMAGETYPE png
PROJECTION
"proj=utm"
"ellps=GRS80"
"zone=15"
"north"
"no_defs"
# OR:
# "init=epsg:26915"
END
LAYER
CONNECTIONTYPE postgis
NAME "geoassets"
MAXSCALE 6000000
CONNECTION "user=johnqpublic dbname=gextest host=pogo password=foo"
DATA "the_geom from streets USING SRID=4326"
STATUS ON
TYPE LINE
CLASS
# All the rest are darker and only 1 pixel wide
COLOR 205 92 82
END
END
END # Map File
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
