[postgis-users] Re: What aplication may i buy to edit postgisdata.
oscar.gomez at telvent.abengoa.com
Thu Aug 28 09:04:49 PDT 2003
Perhaps this helps:
The way ArcSDE solves concurrent access is creating a model that manages a
different version of the hole geodatabase for each database user.
When a user edits some features, the edited table doesn't change at all.
Other tables appear: A (when yo add a new feature) and D (when you delete
a feature) - or both when you just change a feature. System administrator
So, ArcSDE doesn't actually support concurrent editing, geodatabase model
does. Perhaps adding some items to the model, it would be possible to edit
features using versions. That's the way Smallworld does as well.
Another approach would be SDE 3.x one: locking extents to edit.
Best Regards,
Oscar Gomez oscar.gomez at telvent.abengoa.com
IT Consultant Phone no.: +34 - 954 32 18 19
Telvent Fax: +34 - 954 92 64 24
Tamarguillo, 29 URL: http://www.telvent.com
41006 Seville (Spain)
Paul Ramsey <pramsey at refractions.net>
Enviado por: postgis-users-bounces at postgis.refractions.net
27/08/2003 03:22
Por favor, responda a PostGIS Users Discussion
Para: PostGIS Users Discussion
<postgis-users at postgis.refractions.net>
cc:
Asunto: Re: [postgis-users] Re: What aplication may i buy to edit
postgisdata.
I am totally stoked about the possibility of getting a PostGIS
live-edit capability into JUMP. We have a design roughed out, we just
do not have a project to fund the work. It would be pretty cool too --
by doing all the live editing within a transaction block, it would be
possible to rollback or commit complete edit blocks.
One interesting side issue of starting to do live edits within
transactions in PostGIS is improving concurrency in the GiST indexes.
Unlike B-Trees, GiST does not support row-level concurrency. There are
some academic papers on the problem, but no implementations that I know
of. It would be interesting to know how OracleSpatial handles
concurrency in its RTree implementation.
P.
On Tuesday, August 26, 2003, at 10:38 AM, Brent Fraser wrote:
> Chris,
> I just tried JUMP and it looks very intriguing. Over the past
> couple of
> weeks I've been testing various WMS clients with Mapserver, trying to
> find a
> good one that our sales people can use to show our raster data
> products.
> Most have shortcomings when dealing with selecting or setting
> coordinate
> systems.
> I've noticed that JUMP will give the user the opportunity to select
> the
> coordinate system from the list supplied from the WMS server
> (excellent!),
> but there seems to be no way to set the view (task) coordinate system
> so I
> can overlay (and JUMP can project) local lat/lon shapefiles.
> We tend to keep our shapefiles unprojected and let ArcView 3.x do the
> projecting when necessary. This relieves us from have the same data in
> multiple coordinate system (and now that Mapserver can do 24-bit raster
> reprojection and act as a WMS server we may want to do the same for our
> raster data).
> Any plans in the future for JUMP to project local vector data on the
> fly?
> Thanks!
> Brent Fraser
> GeoAnalytic Inc.
> Tel:(403) 213-2700
> bfraser at geoanalytic.com
> www.geoanalytic.com
> ----- Original Message -----
> From: <chodgson at refractions.net>
> To: "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>
> Sent: Tuesday, August 26, 2003 10:16 AM
> Subject: Re: [postgis-users] Re: What aplication may i buy to edit
> postgisdata.
>> I would have to suggest JUMP as a possibility. It doesn't allow
>> in-table
>> editing (yet) but you can suck out a table and edit it, then save it
>> back
> to a
>> new table (with the postgis plugin). This won't work very well if your
> table is
>> too large to fit all in memory at once... eventually there will
>> probably a
>> better postgis plugin with support for in-table editing.
>> http://www.vividsolutions.com/jump/
>> Chris
>> Quoting Wilman Rojas <wilmanrojas at geoweb.com.co>:
>>> We clarify:
>>> We do not want to buy ArcEditor.
>>> Do you know of any other software available for Postgis data
>>> editing.
>>> Thank.
>>> Wilman Rojas.
>> postgis-users mailing list
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
Paul Ramsey
Refractions Research
Email: pramsey at refractions.net
Phone: (250) 885-0632
