[postgis-users] How to generalize or simplify a Polygon
Martin Davis
mbdavis at VividSolutions.com
Thu Aug 28 10:39:22 PDT 2003
Chris, does your D-P algorithm guarantee to return valid polygons? It seems to me that standard D-P does not check whether removing points introduces self-intersections...
Martin Davis, Senior Technical Architect
Vivid Solutions Inc.
Suite #1A-2328 Government Street Victoria, B.C. V8T 5G5
Phone: (250) 385 6040 Fax: (250) 385 6046
EMail: mbdavis at vividsolutions.com Web: www.vividsolutions.com
> -----Original Message-----
> From: chodgson at refractions.net [mailto:chodgson at refractions.net]
> Sent: Thursday, August 28, 2003 10:37 AM
> To: PostGIS Users Discussion
> Subject: RE: [postgis-users] How to generalize or simplify a Polygon
> Quoting Chris Faulkner <chrisf at oramap.com>:
> > Good luck with your search for an implementation of a line
> generalization. I
> > am using Java Topology Suite
> (http://www.vividsolutions.com/jts/jtshome.htm)
> > with postgis and was hoping that they would offer something similar.
> > Unfortunately, it doesn't.
> Either JTS or JCS will have a douglas-peucker algorithm, very
> soon. I've
> already written it :)
> > I would have thought that your expectation that the
> resulting polygon should
> > cover at least as much area as the original is unrealistic. It you
> > generalise a line around a polygon, you change it's shape
> and if you change
> > shape, you change area. Full stop.
> Actually, this is fairly simple and sensible requirement -
> one doesn't want
> their jurisdictional area to be "shrunk" by the
> generalization. I'd rather be
> contacted about something outside my jurisdiction due to a
> generalization
> error, than NOT contacted regarding something that was
> happening inside my
> jurisdiction.
> Geometrically, this means ensuring that non of the points on
> the convex hull of
> the polygon are removed during the douglas-peucker... it
> could be implemented
> with a custom douglas-peucker, that knows it can't delete
> flagged points, or by
> simplifying the shape and then unioning it back with the
> original shape. Either
> way should remove at least some points, but it won't have the
> properties of a
> normally douglas-peucker-ed line.
> However, to simplify an already convex shape without reducing
> its area, is a
> different, and interesting problem - imagine all the points
> of the polygon are
> equally spaced around a circle - you can't remove any point
> with reducing the
> area. The only way to use less points to describe "at least"
> this area, is to
> fabricate new points around the outside (circumscribing the
> circle with a
> polygon that has fewer points). A more difficult problem no
> doubt, and I am not
> familiar with a general solution.
> Anyways, sorry for rambling...
> Chris Hodgson
> postgis-users mailing list
