[postgis-users] shp2pgsql and clockwise vertices?
Hubert Fröhlich
hubert.froehlich at bvv.bayern.de
Fri Aug 29 05:27:58 PDT 2003
Hi list,
I use PostGIS 0.7.5 and PostgreSQL 7.3.4.
I produced a PostGIS table with MULTIPOLYGONS (150 rows) and wanted to
export them to shape with pgsql2shp .
When filling the PostGIS table I t took care about:
- filling only with multipolygons containing 1 polygon with vertices in
clockwise order.
However, when I produced the shapes and examined the data, I realized
that in some (few) shapes the orientation changed to counterclockwise.
Then I tested the same with a modified PostGIS table by deleting some 30
rows. Result: again some shapes with changed orientation, but not the
same shapes as in the first test with the 150 shapes.
What is the reason for this mixing up the shape orientation?
Any hints will be appreciated.
Thanks.
Hubert
Dr.-Ing. Hubert Fröhlich
Bezirksfinanzdirektion München
Alexandrastr. 3, D-80538 München, GERMANY
Tel. :+49 (0)89 / 2190 - 2980
Fax :+49 (0)89 / 2190 - 2459
