[postgis-users] GEOS Installation Testing Help
Darren Houston
darren.houston at edu.sait.ca
Thu Dec 4 13:55:58 PST 2003
Hello everyone.
This is in response to the thread:
RE: [postgis-users] Will someone compile PostGIS 0.8.0 and PostgreSQL 7.4
for Win32 and want to share it?
I have tried multiple times to post to this thread, but something stops me.
So, I have to start a new thread.
I have been following this post and decided to see if my GEOS was
working properly with PostgreSQL.
I tried;
SELECT geomunion(
'GEOMETRYCOLLECTION(POINT(0 0), LINESTRING(1 1))',
'POINT(0 0)'
and I received this error;
NOTICE: IllegalArgumentException: This method does not support
GeometryCollection arguments
ERROR: GEOS union() threw an error!
PostgreSQL isn't affected by the error.
Ok, but the thing is, the PostgreSQL I'm running is the default 7.3.4
PostgreSQL installed fresh from CD when I installed RedHat 9 (with the
latest RedHat RPM updates). Here is some info on my database;
SELECT version();
PostgreSQL 7.3.4 on i386-redhat-linux-gnu, compiled by GCC
i386-redhat-linux-gcc (GCC) 3.2.2 20030222 (Red Hat Linux 3.2.2-5)
ldd /usr/bin/postmaster
libpam.so.0 => ...
libssl.so.4 => ...
libc.so.6 => /lib/tls/libc.so.6
I have no linking to libstdc++ with postmaster. When I compile and install
PostGIS and Geos I compile PostgreSQL from source adding the
LDFLAGS=-lstdc++ (only make, not make install). I then
compile and install Geos and PostGIS into their own directories and use
them with PostgreSQL. So how can Geos work with a PostgreSQL that has no
link to c++, unless Geos just needs it to compile and install, not run?
I have used other Geos functions with success. Any other queries that
would differentiate between a working and non-working Geos?
Thank you for anyone with ideas/information to this.
Darren H.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20031204/93e8ef11/attachment.html>
