[postgis-users] Cygwin installation
Steffen Macke sdteffen at web.de
Tue Dec 16 04:47:03 PST 2003
Meredith,
eventually your postgres user does not have the right to run postgres.exe
Could you try to fix the access rights with
chmod a+rx /usr/bin/postgres.exe
as the administrator of the machine
and try again to run postgres.exe as the user postgres?
If it still doesn't work, have a look at the postmaster log file
c:\cygwin\var\log\postmaster.log
This file might contain an error message that helps you to track down
the problem.
Steffen
