[postgis-users] postgis, postgresql and geological data
Dennis Veatch
dveatch at woh.rr.com
Wed Dec 17 07:42:03 PST 2003
On Wednesday 17 December 2003 10:12 am, Doug_Newcomb at fws.gov wrote:
> Dennis,
> You might check with your local USGS-WRD office,
> http://water.usgs.gov/admin/wrd-dir/OH.html#HDR0 , to see about local
> geological GIS data layers and their existing well database ( I believe
> it's called NWIS) .
Thanks for the link, I will check that out.
> You will probably not be able to get the detailed
> information that it sounds like you want for each well from a generalized
> geological GIS data layer. From what I understand, drillers keep logs on
> how deep they go and what kind of substrate they encounter as they drill (
> x feet of sand, x feet of clay ,etc. ) . If your brother-in-law has such
> information for each well, you can attach it to the geographic points.
Yes, I know (or assumed) the detail information probably is not available.
Though I did find a web site I could input a well log report (for Ohio) and
get some general info about it, but not what I was looking for.
Yes I have the detailed well information from my brother-in-law he submits to
the state so it's just a matter of creating the appropriate tables and
importing that data. A good portion of the well data he has already put into
the cheesy database I made so he could look up customer/well info.
So the actual well data is a minor concern, it's finding the approriate data
set (?) to use so when a well is selected, it's lat/long is placed correctly
over the map.
Another confusing aspect is which do I use? There's DLG's, DEM's, DOQQ's just
to name a few.
My biggest problem is wrapping my brain around this. After monitoring this
mail list for a good while some of the issues I have seen dealing with
geometry, datasets, etc are more or less exactly beyond me. Not that will
stop me trying, this will either be a success or a colossal waste of my
time. :)
> Some background about what I want to do and hopefully someone can point me
> in
> the right direction. My brother-in-law drills water wells and some time ago
> I
> created a customer database so he could look up information about the well
> he
> drilled. The idea I have is to create a database of geological data for
> water
> well drillers and merge/link it to a database of their customers. The state
> of Ohio now requires the well driller to include the latitude and longitude
> of the new well when he submits his report to the state agency.
> Other information they provide on that state report are the underburden
> layers
> they drill through, such as, dirt, clay, sand, gravel, clay/sand,
> gravel/sand, etc.
> He has well records going back to when his father was in the same business
> (about 50 years worth). So in general the goal is to take a wells
> longitude/latitude and overlay that with a map of what was drilled through
> to
> create the well.
> My confusion is where to find existing geological data that I can use as a
> basis, can such data be imported (easily) into Postgis/Postgresql and well,
> there are a number of other things but I don't want to make this post to
> long.
> Any thoughts, pointers or suggestions are greatly appreciated.
> Registered Linux user 193414
> http://counter.li.org
> "Trying"? My contribution was much closer to a "feeble wave in the general
> direction of something that might lead you one step closer to a solution
> if you squint really hard and do all of the work."
> postgis-users mailing list
