[postgis-users] double byte character
Steffen Macke
sdteffen at web.de
Sat Jul 26 23:33:09 PDT 2003
> In the case of shp2pgsql, I think the problem is the Shape format, is it
> not? Can the DBF files store anything other than 8-bit character sets?
I think that Paul is right, the DBF format of the shapefile tables
might be the problem. I don't know about Japanese, but for Arabic, the
following approach works:
"In order to display Arabic map labels, a PostGIS database using
UNICODE should be used. The labels should be TrueType labels with a
UNICODE font that supports Arabic. Arabic shapefiles should be recoded
with iconv from e.g. Windows-1256 to UTF-8 after running shp2pgsql.
After recoding, the Arabic letters have to be shaped, e.g. with the
iText Arabic shaper."
This short description is from the DCMMS Development Guide, available from
http://dcmms.sourceforge.net
Eventually the DCMMS application can provide some code snippets to help
you with recoding/shaping of PostGIS data and the display of it using
Mapserver.
Steffen
