[postgis-users] RE: Getting the nearest street name from GPS point
Luís Mota
luis.mota at iscte.pt
Tue Mar 11 05:23:26 PST 2003
Hi.
I made a small function is plpgsql to do sth lik you say you are needing:
CREATE OR REPLACE FUNCTION pubPlaceNameOfClosestLineStr (GEOMETRY)
RETURNS TEXT AS '
DECLARE
closestLinestring RECORD;
BEGIN
IF srid($1) != 20790 THEN
RAISE EXCEPTION ''SRID must be 20790'';
END IF;
FOR closestLinestring IN EXECUTE
''SELECT arteria, distance(line,geomfromtext(''''''||
substring(astext($1) from 1 for char_length(astext($1))-1)
|| '''''',20790)) AS distance FROM eixos_ctt''||
'' ORDER BY distance ASC LIMIT 1''
LOOP
IF closestLinestring.distance < 50 THEN
RETURN closestLinestring.arteria;
ELSE
RETURN NULL;
END IF;
END LOOP;
RETURN NULL;
END
' LANGUAGE 'plpgsql';
In this case, the maximum tolerance is 50 m. Note that the street name is
the field "arteria" in the eixos_ctt' table.
Bye, Luís
----- Original
