[postgis-users] FW: postgis.sql
Anthony Agoro (C) Anthony.Agoro at ordnancesurvey.co.uk
Thu Oct 16 10:21:35 PDT 2003
 postgis.sql and libpostgis.so.0.7 are in the same location.
Thanks for the offer Paul, our firewall and network connection will not allow such a remote connection.
Perhaps,it's best one un install Postgis and start again.
To note, I have managed to progress, the following is a paste of the error I got when I ran,
psql -d [yourdatabase] -f	postgis.sql
Please see attachment for full details.
"psql:/usr/local/pgsql/postgresql-7.3.4/contrib/postgis-0.7.3/postgis.sql:823: ERROR:  Operator
Def: function postgis_gist_sel(internal, oid, internal, integer) does not exist"
-----Original Message-----
From: Paul Ramsey [mailto:pramsey at refractions.net]
Sent: 16 October 2003 17:59
To: PostGIS Users Discussion
Subject: Re: [postgis-users] FW: postgis.sql
It seems like the postgis.sql you are installing and the libpostgis you
are linking to are not in sync.
Anthony Agoro (C) wrote:
> Hello guys,
> Many thanks for your help.
> I managed to locate the libpostgis.so.0.7 in
> I modified the postgis.sql file manually to point to my libpostgis
> and ran make install again from my postgis directory.
> Please see the log files
       __
      | Paul Ramsey
      | Refractions Research
      | Email: pramsey at refractions.net
      | Phone: (250) 885-0632
      \_
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
This Email and any attachments have been virus checked upon receipt at the Ordnance Survey and is free of all known viruses.
If you have received this email in error, please delete it immediately and notify the sender.
This email may contain confidential information and if you are not the intended recipient, you must not copy, distribute or rely on it.
As email is not a 100% secure communications medium, you accept that there are risks in communicating by email by doing so. We advise you to check that emails and attachments are virus-free before opening them. No contracts can be entered into on our behalf by email. Opinions expressed in this email are not necessarily endorsed by us unless otherwise specifically stated. We reserve the right to read and monitor any email or attachment entering or leaving our systems without prior notice.
Ordnance Survey
Romsey Road
Southampton SO16 4GU
Tel: 023 8079 2000
http://www.ordnancesurvey.co.uk
Type: application/octet-stream
Desc: postgiserror-txt
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20031016/b3a7b489/attachment.obj>
