[postgis-users] PostGIS with Mapserver/Mapscript 4.0
Mike Leahy
mgleahy at fes.uwaterloo.ca
Tue Sep 16 11:36:10 PDT 2003
David,
Thanks for the response, and I apologize for the confusion.
Unfortunately, I think I'm going to have to sit tight and wait until a Win32
build is available. I've already tried compiling/installing the supporting
packages required for Mapserver, and that alone is leading me to more
errors. I don't think I could get this done in a reasonable amount of time.
On top of that, I'm running MapServer with IIS in WinXP...I'm not really
sure if Mapserver compiled in cygwin work for IIS - would it? Is there any
way for me to know when the changes have been updated in Win32 development
version of Mapserver?
The project I'm working on is developing a spatially-enabled education
quality assessment database for use by participants from developing
countries. Our goal is to get something presentable running before
November. While things are working more-or-less with the older 'unknown'
build of PostGIS that we have, I was hoping to take advantage of more useful
functionality in the latest versions.
At any rate, I really appreciate your help.
Kind regards,
Mike
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of David
Blasby
Sent: September 16, 2003 12:37 PM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] PostGIS with Mapserver/Mapscript 4.0
Mike Leahy wrote:
> As a workaround, I changed the USE_GEOS parameter to 0 in the
makefile...so
> I was able to install PostGIS without the GEOS support. Unfortunately,
I've
> come full-circle to my original problem. I'm still getting the warning
> messages tacked onto the end of my PHP script output when performing a map
> query that selects more than one object:
>>WARNING: BEGIN: already a transaction in progress WARNING: Closing
>>pre- existing portal "mycursor" WARNING: BEGIN: already a transaction
>>in progress
>>WARNING: Closing pre-existing portal "mycursor" WARNING: BEGIN: already a
>>transaction in progress WARNING: Closing pre-existing portal "mycursor"
>>WARNING: etc...
Two things, mike;
1. You need to re-compile mapserver, not PostGIS
2. As I said in my last message, I havent actually committed the changes
yet. (I made a bunch of other very minor changes and havent had time to
test them)
I've attached a mappostgis.c that you can use in mapserver that should
solve your problem.
dave
