[postgis-users] GEOS install help for Solaris 9
Paul Ramsey
pramsey at refractions.net
Fri Aug 6 15:12:13 PDT 2004
Start with the XMLTester, that exercises things a bit more.
Matthew Perry wrote:
> Hello,
> We are trying to run postgis on Solaris 9.
> Everything is ok except for the GEOS functions.
> For example, check out the following output from
> psql...
> test=# select intersection('POINT(1 1)', 'POINT(1
> 1)');
> server closed the connection unexpectedly
> This probably means the server terminated
> abnormally
> before or while processing the request.
> The connection to the server was lost. Attempting
> reset: Failed.
> !> select * from pg_tables;
> You are currently not connected to a database.
> The logfile provides the following:
> LOG: server process (PID 19666) was terminated by
> signal 11
> LOG: terminating any other active server processes
> LOG: all server processes terminated; reinitializing
> LOG: database system was interrupted at 2004-08-05
> 13:55:59 PDT
> LOG: checkpoint record is at 0/C75FA8
> LOG: redo record is at 0/C75FA8; undo record is at
> 0/0; shutdown TRUE
> LOG: next transaction ID: 558; next OID: 27382
> LOG: database system was not properly shut down;
> automatic recovery in progress
> FATAL: the database system is starting up
> LOG: invalid magic number 0000 in log file 0, segment
> 0, offset 13066240
> LOG: redo is not required
> LOG: database system is ready
> So is it reasonable to assume that GEOS was not
> installed properly? How would I test this? I noticed a
> little app that comes with GEOS called
> "SimpleWKTTester" but can't make it do anything, nor
> can I find any documentation on it.
> Any ideas? Anyone have any experience with this
> problem on Solaris before?
> Thanks for the input,
> Matthew Perry
> Humboldt State University
> Environmental and Natural Resource Sciences
> postgis-users mailing list
