[postgis-users] libpq.dll conflict between mapserver and postgis ?
Emil Zegers
EZS at Syncera-ITSolutions.NL
Mon Dec 6 06:44:12 PST 2004
Christian,
There are be libpq.dll version cvonflicts between different versions of MapServer and PostGSI.
If you are using the MapServer CGI executable you can 'solve' this by putting the libpq.dll in the folder where the MapServer executable resides.
Emil
>>> Christian.Martel at drdc-rddc.gc.ca 12/06/04 03:40pm >>>
Hi
Setup :
PostgreSQL 8.0.0 beta 2 + PostGIS 0.9.0 (Jean David Techer's windows binary,
sept 23)
MapServer 4.2 (windows)
Problem :
With two libpq.dll in windows path, the postmaster won't start.
If a remove the older one (from MapServer), I can't see my postgis layer in
mapserver.
Is it a dll problem or my map file is not well written ? I see the
background color and I checked the extent.
MAP
NAME PGIS
EXTENT 710000 1837000 742000 1859000
SIZE 500 500
IMAGECOLOR 210 255 255
LAYER
CONNECTIONTYPE postgis
NAME "test"
CONNECTION "user=postgres dbname=testgis host=myserver
port=5432"
DATA "geom from villescommunes"
TYPE POLYGON
STATUS ON
END
END
Thanks,
Christian
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
