[postgis-users] Adding SRID after the fact
RIBOT, Nicolas
nicolas.ribot at astrium.eads.net
Wed Dec 15 00:42:34 PST 2004
> What people thing about a
> SELECT UpdateGeometrySrid([<schema>],<table>,<field>,<newsrid>);
> function ?
For sure, a very useful function, as SRID handling is not easy for basic
postgis users.
Nicolas Ribot
CE COURRIER ELECTRONIQUE EST A USAGE STRICTEMENT INFORMATIF ET NE SAURAIT ENGAGER DE QUELQUE MANIERE QUE CE SOIT EADS ASTRIUM SAS, NI SES FILIALES.
SI UNE ERREUR DE TRANSMISSION OU UNE ADRESSE ERRONEE A MAL DIRIGE CE COURRIER, MERCI D'EN INFORMER L'EXPEDITEUR EN LUI FAISANT UNE REPONSE PAR COURRIER ELECTRONIQUE DES RECEPTION. SI VOUS N'ETES PAS LE DESTINATAIRE DE CE COURRIER, VOUS NE DEVEZ PAS L'UTILISER, LE CONSERVER, EN FAIRE ETAT, LE DISTRIBUER, LE COPIER, L'IMPRIMER OU EN REVELER LE CONTENU A UNE TIERCE PARTIE.
This email is for information only and will not bind EADS Astrium SAS in any contract or obligation, nor its subsidiaries.
If you have received it in error, please notify the sender by return email. If you are not the addressee of this email, you must not use, keep, disseminate, copy, print or otherwise deal with it.
