[postgis-users] Adding SRID after the fact
strk at refractions.net
Wed Dec 15 04:59:47 PST 2004
On Wed, Dec 15, 2004 at 09:42:34AM +0100, RIBOT, Nicolas wrote:
> > What people thing about a
> > SELECT UpdateGeometrySrid([<schema>],<table>,<field>,<newsrid>);
> > function ?
> For sure, a very useful function, as SRID handling is not easy for basic
> postgis users.
The function has been added in the HEAD branch (upcoming 1.0RC1).
It is untested for PG<800.
--strk;
> Nicolas Ribot
> CE COURRIER ELECTRONIQUE EST A USAGE STRICTEMENT INFORMATIF ET NE SAURAIT ENGAGER DE QUELQUE MANIERE QUE CE SOIT EADS ASTRIUM SAS, NI SES FILIALES.
> SI UNE ERREUR DE TRANSMISSION OU UNE ADRESSE ERRONEE A MAL DIRIGE CE COURRIER, MERCI D'EN INFORMER L'EXPEDITEUR EN LUI FAISANT UNE REPONSE PAR COURRIER ELECTRONIQUE DES RECEPTION. SI VOUS N'ETES PAS LE DESTINATAIRE DE CE COURRIER, VOUS NE DEVEZ PAS L'UTILISER, LE CONSERVER, EN FAIRE ETAT, LE DISTRIBUER, LE COPIER, L'IMPRIMER OU EN REVELER LE CONTENU A UNE TIERCE PARTIE.
> This email is for information only and will not bind EADS Astrium SAS in any contract or obligation, nor its subsidiaries.
> If you have received it in error, please notify the sender by return email. If you are not the addressee of this email, you must not use, keep, disseminate, copy, print or otherwise deal with it.
> postgis-users mailing list
